Why does my civic do this.
Old Nov 16, 2009 | 06:38 AM
1.6vx's Avatar
Default Why does my civic do this.
When i'm on the fway doing more than 60 mph the car will go to the right when i accelerate and when i let of it goes to the right.. BAD.
Old Nov 16, 2009 | 06:49 AM
OMGWTFBBQ!'s Avatar
Default Re: Why does my civic do this.
Sounds like an axle/transmission issue. Do you have any ticking/clunking when you turn at low speeds?
Old Nov 16, 2009 | 06:52 AM
jdmwojo's Avatar
have you gotten an alighnment
Old Nov 16, 2009 | 06:54 AM
alexg2009's Avatar
So it goes to the right no matter what?
Old Nov 16, 2009 | 07:29 AM
1.6vx's Avatar
No the car runs straight does not make any clinking noises or need alignment (done just in case) has a different tranny because i though the tranny was the issue. When i'm on the freeway the car will go the right when i accelerate and will go left when i let the gas go back straight or quit pulling the right.
Old Nov 16, 2009 | 07:35 AM
whitetoy's Avatar
Broken left axle, maybe? Jack up the left, and see if the wheel turns.
If it turns, the axle shaft (not the CV) might be broken.
Old Nov 16, 2009 | 07:37 AM
EGed up from the seat up's Avatar
x2, it sounds like an axle problem
Old Nov 16, 2009 | 07:39 AM
CRX T-Si's Avatar
Check your mounts, 1 might be broken causing the engine to move and making your axles articulate at a bad angle causing drag.
Then check your wheel bearings, jack up the car and turn the wheels to see how smoothly it turns. You need to do this for both front and back.
Old Nov 16, 2009 | 08:51 AM
1.6vx's Avatar
have another two axels will swap both tonight and will let you guys know. wheel bearing are good.
Old Nov 16, 2009 | 03:08 PM
b16binside's Avatar
axels,alignment issues,brakes sticking it could be one of many problems
bluevic99
Oct 9, 2011 04:55 AM
3Rd_gEn_LuDE
11
Feb 7, 2011 05:51 PM
josh green
Aug 3, 2004 07:51 PM
ha-evolution
Dec 30, 2002 12:49 AM
