2000 civic, hard to start
Old Nov 15, 2009 | 06:24 PM
BOMBCRU's Avatar
Default 2000 civic, hard to start
2000 civic lx auto 190k- woman driver
CEL catalist low thrushhold
When you go to start it, it stumbles, you have to 1/4 throttle it and play with it sometimes unless the car is already warm, then it starts fine. Its liek its running on 2 cylinders and smells rich, but it runs fine after 10-15 seconds, with no problems after.
It has new:
main relay (this fixed the prob last time it wouldn't start but didn't fix this)
spark plugs
wires
cap
rotor
fuel pressure regulator
fuel pump
new primary o2
And nothing fixed the issue
I can't keep putting money in to this car. Anyone got a dead on fix. Only thing I can think of is distributor may be going out or faulty ecu, injectors sticking or not firing
Old Nov 15, 2009 | 06:58 PM
redm3turbo's Avatar
Default Re: 2000 civic, hard to start
sounds like main relay to me...
happened in my ef.
After you get it running, when it warms up, any issues starting it? or it just the first start every day?
Old Nov 15, 2009 | 07:40 PM
BOMBCRU's Avatar
Already replaced main relay, 3 weeks ago, did not solve this issue. Only does it on cold starts
Old Nov 15, 2009 | 08:08 PM
Former User's Avatar
So you have CEL code P0420, right? Any other CEL codes?
What color is spark at the plugs? My first guess would be a bad coil or ICM in the distributor or possibly a bad distributor sensor.
Old Nov 15, 2009 | 08:14 PM
itsnotfast's Avatar
You need a new catalytic converter, start with that.
Old Nov 16, 2009 | 06:02 PM
BOMBCRU's Avatar
If cat was clogged it wouldnt run, or as good as it does when warm
It had codes missfire 1-4 but not now?
Old Nov 16, 2009 | 06:18 PM
azandford's Avatar
I would replace the whole dizzy. I had a similar problem to the T, it was a bad coil
Old Nov 16, 2009 | 07:06 PM
itsnotfast's Avatar
The CEL is saying the cat is not flowing up to spec. It would only not run if it was completely clogged and it would likely blow the exhaust apart or blow the motor. It needs to be changed the car is telling you that. Werather this is relevant to your problem or not it needs to be done.
Old Nov 16, 2009 | 07:23 PM
itsnotfast's Avatar
A bad cat does not necessarily mean its clogged.
He didn't say it had misfire codes, just that its "like its running on 2 cylinders"
Old Nov 16, 2009 | 08:23 PM
eghatch4sale's Avatar
I got a good dizzy if u want to try it shoot me a text
Old Nov 17, 2009 | 02:41 PM
BOMBCRU's Avatar
14 Electronic air control valve (EACV)
45 Fuel system out of range - rich or lean (cel on)
71 through 74 Cylinder misfires
Old Dec 4, 2009 | 06:01 PM
BOMBCRU's Avatar
head gasket was blown on all 4 cylinders, just got done doing it wed, and so far its running good, and starts good, no issues yet, but still throwing codes after clearing them.
Old Dec 4, 2009 | 06:54 PM
shogee's Avatar
what kinds of codes
BlitzSix
Aug 25, 2010 11:52 PM
armt dude
May 10, 2010 05:19 PM
tamadrummer1120
Nov 28, 2009 09:50 PM
dope93si
Aug 23, 2004 08:52 AM
