need help with b16 head reassmble.
Old Nov 15, 2009 | 01:38 PM
RACEPAK's Avatar
Default need help with b16 head reassmble.
hello everyone,
so i had this head laying around for a few years, and i dont remember how should i reassmble it,
ok...
i cant remember which side of the rocker arms oil rail/rod needs to go to,
does the notched side goes to the timing side? or the tranny side?
other side:
also, i cant remember which oil nozzle goes where... do they lock the oiling rods? i cant remember :S
please help... thanks,
Old Nov 15, 2009 | 08:06 PM
all-mtr-teg's Avatar
Default Re: need help with b16 head reassmble.
The oiling jet tops must be installed in the side clear the cam caps. Look at the bottom of the cam caps on both the exhaust cap 1 and the intake cap 1 (which are on the timing belt side), there are small holes for the top of the oil jets to fit into. One cap has a smaller hole than the other. Those oil jets drop down into the rocker arm oiling shafts so make sure that the hole on the rocker arm shafts is facing up for the oil jets to sink into.
RACEPAK
Nov 25, 2009 07:26 AM
THC07
13
Feb 14, 2007 06:39 PM
89s1
Aug 9, 2004 02:32 PM
kerby116
Mar 6, 2004 11:57 PM
LudeyKrus
Jan 27, 2004 10:28 AM
