can i rev 9k
ok so i have a 94 gsr ls vtec w b18b block
new bearings
new crower econo h beam rods
arp bolts
gsr oil pump water pump and timming belt
je 9.2-1 forged pistons
stock 95 gsr head and skunk 2 pro 1 cams /w aem adj gears
with custom gsr intake w secondarys removed
i haven boosted it yet but i tuned it on s300 in a p06 it made 137 hp and 101 ft-lbs so it did ok with no boost and aconservative tune i reved to 7.5 and the curve didnt drop can i twist it to 9k once and a blue moon without causing damage or what do yall think i can do
new bearings
arp bolts
that's a lot of needless info just to ask a question already in the post title..
what you should ask is what are the limitating factors relating to rev. limit?
when you figure that out, you can look at everything you've done with the motor and decide if the results are worth the risk. will the rod go through the block..? will a valve drop, turning the piston into a grenade? you're call.
new bearings
arp bolts
new bearings
arp bolts
Ag-Eng
Oct 6, 2003 04:15 PM
Imadreamer1226
Apr 4, 2003 10:12 PM
