Question? does advancing or retarding a camgear affect ignition timing...
Old Aug 31, 2002 | 06:36 PM
powerfulperformance's Avatar
Default Question? does advancing or retarding a camgear affect ignition timing...
As the question says. I just wanted to know if I adjust my toda cam gears, will it also change my timing...
Old Aug 31, 2002 | 06:44 PM
Eric R's Avatar
Default Re: Question? does advancing or retarding a camgear affect ignition timing... (powerfulperformance)
Timing is reated to spark and piston (crank) position. Cam gears just adjust the opening and closing of exhaust and intake valves earlier or delayed depending upon adjustment.
Old Aug 31, 2002 | 06:47 PM
D's Avatar
D
distributor is driven off of the intake camshaft... so, if you adjust your intake valve timing, it will affect your ignition timing.
D
Old Aug 31, 2002 | 06:57 PM
Eric R's Avatar
Default Re: Question? does advancing or retarding a camgear affect ignition timing... (D)
D
You're right, I forgot about that point
Treyschls
Apr 13, 2023 07:04 AM
Berto24
Dec 3, 2016 10:47 AM
Mugen_DC2R
Jun 18, 2007 08:04 AM
Mr.Integra
May 22, 2003 12:41 AM
N1Spec
Nov 18, 2001 11:15 PM
