can i keep my hood if i do a j series swap?
Old Nov 13, 2009 | 11:33 PM
HOODRICHZEKE's Avatar
Default can i keep my hood if i do a j series swap?
If I do a j series engine swap into my 93 civic ex coupe would it be possible to keep my hood without cutting it. could I lift it enough of anything? I've heard you cannot but there is a video on youtube where a guy with a ej2 (pretty similar to my ej1) has the swap and still has the hood uncut. If anyone could clarify this for sure for me it would be a big help thankyou.
Old Nov 13, 2009 | 11:42 PM
Got traction's Avatar
Default Re: can i keep my hood if i do a j series swap?
the answer is no. link to video?
Old Nov 14, 2009 | 12:19 AM
thumper64's Avatar
Depends on your mounts. Early ones wouldn't let the hood clear, but newer ones sit the motor lower and tilted different.
Old Nov 14, 2009 | 01:22 AM
burningrex's Avatar
i seriously doubt it will ever fit...
get a k instead... more aftermarket support...
Old Nov 14, 2009 | 02:12 AM
you ask, and you shall receive.
http://www.youtube.com/watch?v=p64BZ...layer_embedded
Do you know what brand or by chance know a direct web page or link to where I could find this?
My expenses don't stretch that far. a j35a4 only runs about 900-100$ and then I have to get new axles, mounts, harness, ecu, and tranny. as with any typical swap. The j series can just get done cheaper, being the reason I would really like to do this swap. plus it's a head turner to see a v6 in a coupe not to mention just plain bada@#.
Old Nov 14, 2009 | 05:11 AM
miguel329's Avatar
good luck with the build, i wanted to go this route just cant see parting out my gsr turbo build... some of the guys make custom mounts to get it under the hood. plus if you ever want to build that motor it wouldnt be cheap, now you got headwork for 2 heads, need 6 rods intead of 4 and list goes on.. send me some pics when you get it done.
Old Nov 15, 2009 | 06:11 PM
splatV6's Avatar
My friend just made a kit for a 92-95 civic.
Hes working on other things and so far this is the only kit that allow the hood to close as close. as possible.
Let me know if you are interested in a kit.
Old Nov 15, 2009 | 08:52 PM
b16binside's Avatar
yeah my buddy just put one in his ITR and he isnt even running a hood yet and its been running for almost three weeks now.
Old Nov 15, 2009 | 10:45 PM
fastrxu's Avatar
The hood is the least of your problems with this swap
Hybrid Racing makes pretty much everything for the swap. The got mounts,axles, a/c and power steering kits
And theyre mounts will retain your stock hood
toytroy
K Series
Jan 1, 2015 06:44 AM
joukaishou8139
Feb 21, 2010 04:59 PM
manicmechanic
Jun 28, 2009 09:10 AM
craphatch
Welding / Fabrication
Apr 15, 2009 04:36 PM
Rratedcivichatch
35
Feb 27, 2003 09:41 PM
