VIS Carbin Fiber hood fitment on b series swap hatch....?
just installed my vis cf hood on my hatch. it has a b series swap and everything seems ok except the hood hits the valve cover causing it to lift on one side. do any of you have this problem? its not a problem, it's just that it throws off the alignment a little with the fenders. its a grade a or aa vis hood with rolled sides. thanks, any info or suggestions are appreciated. thanks again.
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (Rratedcivichatch)
Which B series motor? I've heard that the b18c1 hit the bottom of the hood. I saw somewhere about them lowering the engine into the chasis. causing the header to be to low. Im also trying to find info on this since i have a VIS hood.
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (Spooner)
i have a jdm type r swap. it hits it and one side is a bit higher. im glad im not hte only one. i dont want to spend money lowering my motor haha. are there any other ways about going at it, ie. shaving some of the underhood part? heh thanks
get some extended bolts and a bunch of washers. the bolts go throw the latch through a bunch of washers and then threaded into the hood. use as many washers as it may take to keep the hood from hitting. this will lift the rear part of the hood up but it looks dope IMO!!
-Bryan-
-Bryan-
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (EGStreetHtch)
-Bryan-
-Bryan-
Anyone of you guys tried it already??...let me know what happens....i have the same problem....thanks
-Bryan-
-Bryan-
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (dwnthehatch)
PM "pkek" he has a VIS cf hood on his b16 powered hatch.
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (acura_typer)
i dont mind the fitment if one side is off, its fine with me. i was just thinking it should fit and if anyone else had a problem with them. i guess im not the only one. maybe someone should write to them... heh. i wonder why stock hood clears b series swap tho?
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (ekfour)
Duh, cut the bracing under the hood where it hits the motor.
w3rd.
or just cut the valve cover and save the hood.
[Modified by ekfour, 7:24 PM 11/21/2002]
lol
What hood stlye are you guys using? I was about to order an OEM style VIS c/f hood but not sure if I want to now. I will be installing a GSR motor within a couple weeks.
My friend has a GSR motor in his EG hatch. Has the invader style c/f hood and had to get all the support brackets sanded away because it was rubbing the valve cover
Will the OEM hood clear the GSR motor without any problems?
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (Hybrid93Hatch)
My friend has the VIS hood that has the vent in the middle of the hood it fits fine intil we but a B18c in it. Now the hood sets up a little so he just put spacer in it, it does not look to good, just my opinion.
Location: Toronto, Canada currently residing in ATL, GA, USA
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (ITR632)
OEM style VIS hood willl rub the paint off the corner of your valve cover. I had one and it happened to me. The front of my car is tweaked so I thought it was due to that. When I buy another one I'm cutting some the skeleton away from the point that hits the valvecover.
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (Apex i ITR)
I'm going to find a pic of the underside so I can see what there is to work with and cut.
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (Si-G93)
Very little needs to be shaved, cut (Whatever you want to call it). My hood had a little indentation were it was hitting the valve cover.
Its not hard. Esp if you have a dremel.
I have herd that the Mosumo or whatever valve cover is lower in height than the R covers
official honda whore
Re: VIS Carbin Fiber hood fitment on b series swap hatch....? (greebler)
i had a fiber images hood with my b18c swap, no problems with anything hitting, but it also was the hood w/o the skeleton underneath
On a side note, does you VIS hood have a rivited VIS plate near the latch??
