95 Dodge Neon-Mild All Motor Build
Old Nov 13, 2009 | 05:51 PM
streetspeedneon's Avatar
Default 95 Dodge Neon-Mild All Motor Build
Hello all, My name is James, Im from Chesapeake, VA. This is my build log on my 95 Dodge Neon.
The goal Im going to reach is 185whp. 2.4L DOHC swap, Crower Stg 3's and all supporting mods.
Current Mods:
2.0L DOHC swap
OBX Mid length header
Ported Intake manifold
Street ported head and milled .020
55mm TB
OBX UDP
MSD coil
Avenger oil pan
Mopar Front MM
Prothane MM inserts
Welded Bobble strut
Walbro 255 lph
Future Build:
2.4L swap
Crower 3/4 Race(Stg 3) Cams--check
Fidanza cam gears
Crower valvesprings--check
ARP head studs/rod bolts(LS1)--check
Custom Long tube header
De-90* Intake Manifold--check
55mm TB--check
3.94/.81 5th Tranny
Mopar PCM
SAFC 2
Full Port Job on Head--check
Old Nov 13, 2009 | 08:39 PM
J_Marc's Avatar
Default Re: 95 Dodge Neon-Mild All Motor Build
Nice Neon, a friend of mine had one exactly like that a few years ago. When I read the title, it kind of surprised me to see you're doing an all motor build. Are you sticking with the 2.0 or building a 2.4? Making big power with them all motor isn't easy, but your power goal and quarter mile time seems attainable. What kind of wheels are those by the way?
Old Nov 14, 2009 | 10:05 AM
thanks. Im staying with the 2.0L. If I was doing a 2.4L I know that I can set a higher goal. but I want to have some fun with the 2.0L.
The wheels are 15x6.5" RS-L Ikaris
Old Nov 15, 2009 | 07:40 AM
bad93ex's Avatar
The NGC from what I have read seriously robs any gains from bolt-ons.
Old Nov 17, 2009 | 06:04 AM
RoysNeon's Avatar
NGC started in 2003.
You can hit 175 stock bottom with bigish cams. AFAIK 18's are good for it stock bottom.
Cool to see you here James.
Old Nov 18, 2009 | 07:53 PM
Thanks Roy. yeah, they say that the Crower Stg 3 has the same lift as the #18s, and duration of the #22s...not sure tho. I have the specs but Im too lazy to look them up.
I just replaced the rod/piston, and bearing on my #1 cylinder and I should have everything back together this weekend. I needed a head gasket and stuff.
Old Nov 19, 2009 | 12:09 PM
bad93ex's Avatar
Did not know thanks for the info.
I am the not-so-proud owner of a 00 neon that I am debating to dump money into.
Old Nov 20, 2009 | 10:13 AM
RoysNeon's Avatar
Put a DOHC head on it.
Old Nov 25, 2009 | 09:31 PM
January 2010...New block with all new rod bearings and ARP rod bolts.
February 2010...Crower Stg 3 Cams, Crower valvesprings, De-90* intake mani.
March 2010...Track time!
Engine pics(not recent)
Old Apr 30, 2010 | 06:06 AM
Its been a while, but I been real busy with the new job, move, and my music. but Ill be picking up my block in about 2 weeks along with a few other things. Crower cams will be here in July along with valvesprings, SAFC, modded intake manifold and more. Stay tuned.
Old May 3, 2010 | 08:46 AM
kimlover1's Avatar
Keep us updated.
Old May 3, 2010 | 01:38 PM
dragneon's Avatar
nice, glad to see another neon on here
Old Feb 25, 2011 | 05:24 AM
Im BACK! The Neon is still in pieces but there is Progress...
Crower Stg 3 cams, Crower valvesprings, no 90* intake plenum, PT upper/lower alt brackets, ARP rod bolts, New rod bearings, Race Bobble strut, SRT timing belt tensioner, and more. Car is still in storage. New block coming in 2 weeks.
Old Feb 25, 2011 | 05:51 AM
I just ordered some brand new OEM headlights and 8000k HID kit...
Old Feb 26, 2011 | 02:24 PM
spliftacus's Avatar
lol this car beat my swapped coupe years ago. It rolled out. Keep up the good work JMOE
Old Feb 27, 2011 | 09:08 AM
What up Mannie! I was SOHC then, Im now DOHC, swapping to a 2.4L I cant wait to finish this build. I still wont be able to **** with your GSR-Turbo tho...we need to get up.
Old Mar 19, 2011 | 04:19 PM
Painted some parts...
hondalifestyle29
Northwest (Sales)
17
Apr 3, 2010 02:59 PM
93hondaboy
Dec 1, 2008 05:59 AM
VTEC2841
12
Jun 2, 2007 08:36 PM
teg92
Jan 15, 2002 09:32 AM
