what's the most power you made on a stock h22 and how long did it last
Old Nov 13, 2009 | 02:11 PM
hondastudent1on1's Avatar
Default what's the most power you made on a stock h22 and how long did it last
ok am seeing jdm h22's selling for 720$ on ebay, please tell my why I should spend 3600 for a built one when 350hp is the safe for pump gas and the stock h can produce.
Old Nov 14, 2009 | 05:07 AM
JDM H2B EK's Avatar
Default Re: what's the most power you made on a stock h22 and how long did it last
i cant tell you why.... because i dont know... lol i obviosly drive a stock boosted h22 on 10 psi and make 345whp... only problem im havin is my clutch slippin and ive been driving it some what hard for about a year now... yes the cylinder walls are weak and so are the ring lands but its all in the tune... ive just purchased a water meth kit and will be turning the boost up a lil bit ill post results
Old Nov 14, 2009 | 05:26 AM
atec's Avatar
100% stock h22, 367whp 11psi, lasted 5 months before spun a bearing and broke the rod.
same, 321,7whp 11psi(ebay crap) lasted two years.. customer decided to sell the car, havent heard anything since..
Old Nov 15, 2009 | 12:59 AM
wow great numbers guys
Old Nov 15, 2009 | 01:03 AM
what turbo are you guys running with?
Old Nov 15, 2009 | 01:19 AM
extralargenog's Avatar
The SEARCH turbo. Try it
Old Nov 15, 2009 | 12:15 PM
thanks but I dont need search for a turbo, I have a gt35r on a bone stock h22 in a crx making 330hp(7psi) for almost a year now.
Old Nov 15, 2009 | 12:37 PM
here
Old Nov 17, 2009 | 09:45 AM
speedworks's Avatar
421whp and 315 tq at 11psi......almost 18 months......No problems on Bigblockhatch's eg
Old Nov 17, 2009 | 12:15 PM
wow, on a stock motor?
Old Nov 22, 2009 | 08:30 AM
mycarslow's Avatar
bump id also like to know
Old Nov 24, 2009 | 09:09 AM
Bigblockhatch's Avatar
Yes the motor is 100% stock internal longblock.....It has had a little over 17k miles put on it since it was turboed....T67 with a .82 back side on 11.3 psi.....E85.....We hope to reset the stock block record on this motor.....
Old Nov 24, 2009 | 09:15 AM
boostedeg302's Avatar
thats sick. good luck on the record
Old Nov 24, 2009 | 09:23 AM
ReDemoN's Avatar
DixielandImports Please
There is a guy around here that has a stock H22.
He make like 550 or something like that.
Now it may not be a "stock" engine.
I do know the block and head are stock.
I think he built his own I/M.
Old Nov 24, 2009 | 10:41 AM
Specail Ed's Avatar
Mine made 298 with a T3/T04E at 10psi and lasted about 2 years. Then the ringlands decided to fall off the pistons. Stupid ringlands.
civtic
48
Feb 11, 2008 07:47 PM
sohctodohc
Aug 28, 2005 07:36 AM
redlseg
Jul 18, 2005 09:10 PM
Beau Gotti
Feb 15, 2005 09:31 AM
504tuner
Dec 15, 2004 02:19 PM
