ABS light turned on after installing..
Old Nov 12, 2009 | 08:14 PM
1996cd7jjs's Avatar
Default ABS light turned on after installing..
My lowering springs. now i checked everything and all the lines are okay.
the drop wasn't that much either, so the lines are not rubbing on anything.
now i don't know but i think its my passenger side cv joint is busted and leaking
oil all over the place, now can it be the sensor that went out because of
the cv joint being busted or is it cause of the drop??? or can the grease from the
cv joint trigger the sensor to read wrong and cause the light to be on??
help much appreciated thanks
Old Nov 13, 2009 | 03:54 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: ABS light turned on after installing..
Check to make sure the wheel sensors are clean. They are magnetic and could have picked up some debris. Also, pull the ABS codes. (Paperclip in the passenger kick panel jumper, turn on key, read ABS light for codes.)
Old Nov 13, 2009 | 05:19 AM
1996cd7jjs's Avatar
Hmm okay i'll check it out..
don't know where the sensor is located
but i'll look for it
Thanks man
Old Nov 13, 2009 | 06:32 AM
Dogginator's Avatar
Daisy... Daisy...
Look for a wires running to the hubs.
Old Nov 13, 2009 | 02:40 PM
spoolin94ls's Avatar
Make sure the abs module has brake fluid in it, or the light will come on. Mine does the same thing when the module get low on brake fluid.
Old Nov 13, 2009 | 08:55 PM
1996cd7jjs's Avatar
hmmm well the sensor wasn't dirty
but i will check to the fluid thanks
man!
Old Nov 14, 2009 | 04:55 AM
Dogginator's Avatar
Daisy... Daisy...
You can keep guessing or pull the codes, as they will tell you why the light is on.
Old Nov 14, 2009 | 06:31 AM
1996cd7jjs's Avatar
Well i'm going to do that today i
just hadn't have time, but i'll pull
the code and see what it is.
94BlkCivicEx
12
Oct 22, 2009 08:49 AM
dartonh22
Honda S2000
13
Jun 24, 2008 01:17 PM
FLATOUTRACING
Dec 11, 2005 03:06 PM
MF-DIF
Feb 11, 2004 05:35 PM
JimmieD
Jan 14, 2002 08:02 AM
