Honda S2000 Honda S2000
ABS light on:(
Old Jun 21, 2008 | 09:30 AM
dartonh22's Avatar
Default ABS light on:(
my abs light and brake light are both on, i am figuiring the sensor is bad but i dont know which one, my buddy's uncle owns a garage but doesnt have the software for the abs scan tool, anyone now ehre to get it, and would the brake light be on as well because of a faulty sensor.
i did not lower the car or mess with the suspeneion i bought the car with this light on.
Old Jun 21, 2008 | 09:39 AM
papa5murf's Avatar
Default Re: ABS light on:( (dartonh22)
The ABS thing is up front in the engine bay drivers side. Make sure it's plugged in.
Old Jun 21, 2008 | 10:01 AM
dartonh22's Avatar
ok i'll check that, does the abs sensor on the S look like the older hondas on the back of the brake pointing at the axle ring or is it different.
Old Jun 21, 2008 | 10:09 AM
papa5murf's Avatar
There's a wire connected to a connector clip that you plug into a box. Just look up near the drivers side headlight. Just look for anything that is not connected doesn't look right. If everything there is fine, it's something else that's causing the issue.
Old Jun 21, 2008 | 10:17 AM
Black S2K's Avatar
check the wheel sensors brake dust and other debris colects on them and they start acting up. So clean the bitches.
Old Jun 21, 2008 | 10:45 AM
papa5murf's Avatar
Default Re: (Black S2K)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Black S2K &raquo;</TD></TR><TR><TD CLASS="quote">check the wheel sensors brake dust and other debris colects on them and they start acting up. So clean the bitches.</TD></TR></TABLE>
Collects. Not colects.
Old Jun 21, 2008 | 01:29 PM
Black S2K's Avatar
thanx dorkface
Old Jun 23, 2008 | 12:09 PM
dartonh22's Avatar
alright well i checked the fuse box again and i dont know how i missed it but the abs motor fuse isn't even there, any idea why this may have been pulled before i put another one in?
Old Jun 23, 2008 | 12:11 PM
Chris.'s Avatar
Honda-Tech Order of Merit
Default Re: (dartonh22)
maybe another fuse blew and a previous owner was too cheap to buy a new one?
Old Jun 23, 2008 | 01:12 PM
bigmacnfries's Avatar
Default Re: (Chris.)
it does sound like a problem is occurring - otherwise they wouldn't have removed the fuse - stick a new one in and keep fingers well crossed.
Old Jun 23, 2008 | 01:49 PM
dartonh22's Avatar
Default Re: (bigmacnfries)
yeah i bought a new one and the light went out but my brake light is still on. anyone have a list of what causes this light to come on, i know the ebrake, low fluid and a light out will cause it to come on and all those are checked good.
Old Jun 24, 2008 | 10:18 AM
dartonh22's Avatar
alright well i think its my float causing the brake light to stay on, if i unplug the clip on the resevoir, the light goes out, and i filled up the resevoir, but that wont do it, and my top will not go down without the e brake up so its not that switch, anyone ever had the float go bad?
Old Jun 24, 2008 | 10:21 AM
joey1320's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dartonh22 &raquo;</TD></TR><TR><TD CLASS="quote">alright well i think its my float causing the brake light to stay on, if i unplug the clip on the resevoir, the light goes out, and i filled up the resevoir, but that wont do it, and my top will not go down without the e brake up so its not that switch, anyone ever had the float go bad?</TD></TR></TABLE>
yeah i replaced 6 over my 2 1/2 years at Acura. the foam just gets hard and sinks to the bottom, telling the ecu that the reservoir is empty. they were like $35.
Old Jun 24, 2008 | 01:17 PM
dartonh22's Avatar
Default Re: (joey1320)
cool do i take the resevoir apart, cuz its different then most honda resevoirs ive seen. can you tell me how to take it apart or is it self explainatory?
fotoforce
Aug 21, 2018 03:56 AM
1996cd7jjs
Nov 14, 2009 06:31 AM
RotaryPWR
Aug 12, 2009 11:36 AM
FLATOUTRACING
Dec 11, 2005 03:06 PM
MF-DIF
Feb 11, 2004 05:35 PM
