s300
Old Nov 12, 2009 | 06:19 PM
bigtom388's Avatar
Default s300
i got the hondata s300 with boost control option but i cant get the boost by gear to work i have to use the percent way if anyone knows how to set this up correctly that would be awsome thanks.
Old Nov 12, 2009 | 06:44 PM
runsfromdacops's Avatar
Default Re: s300
Goto the hondata web site its be covered over there a lot. Some say it works great some can never get it to work at all.
Old Nov 12, 2009 | 10:44 PM
omiehomie's Avatar
Default Re: s300
did you get a MAC solenoid / valve? and wire it in to pin 11 i think?
Old Nov 13, 2009 | 11:52 AM
bigtom388's Avatar
Default Re: s300
Yea Joe Simpson from tempest racing looked over all that while he was tuning my car and said it was done correctly I'm just tired of hitting boost cut and I know of I het this to work I won't have to worry bout that
Old Nov 13, 2009 | 01:32 PM
champLSinteg's Avatar
Default Re: s300
You need to fill Pressure vs Duty Cycle table. Set it to fixed duty cycle and do a few pulls with increasing duty cycle percentages and record the pressure you get from them. Now take those number and plug them into the pressure vs duty cycle table. Once that is done you can enter a pressure number in the boost by gear table. Thats worked for me.
Old Nov 13, 2009 | 08:26 PM
bigtom388's Avatar
Default Re: s300
when you say record the pressure do you mean how much boost i make at that duty cycle % and what should i start the duty cycle at sorry for asking so many ?'s im new to all this
Old Nov 14, 2009 | 03:32 AM
inspector01's Avatar
Default Re: s300
start at 0% duty cycle, do a pull. That should be wastegate boost. Then slowly increase it 5-10% at a time till it starts increasing boost. Keep doing this till you get to the max boost you are going to run, record the boost level you get at each duty cycle. Now enter the duty cycles into your charts and play around with it till you get the boost you desire.
Old Nov 14, 2009 | 07:14 AM
bigtom388's Avatar
Default Re: s300
ok cool got it thanks alot guys u guys were a big help ill let ya know how it turns out
2kdrift
Engine Management and Tuning
Apr 6, 2016 12:09 PM
Tw34k
Feb 1, 2013 03:08 PM
airwalk07143
Aug 6, 2008 04:32 AM
Jared
Feb 27, 2006 07:25 PM
