what valves to use for b16a1?
Old Aug 31, 2002 | 03:58 PM
Frcfedintegra's Avatar
Default what valves to use for b16a1?
what valves do you recomend for a n/a b16a1 with i/h/e, need valves, valve guides, and what mm valve do i need to get?
Old Aug 31, 2002 | 05:25 PM
spettinger's Avatar
Default Re: what valves to use for b16a1? (CivlizdSir)
skunk 2 lightweight valves. same size. as for valve seals, portflow sells them, i am not sure if they are stock. look at Eric's and Ferrea for valve seals as well.
Old Aug 31, 2002 | 08:34 PM
bryant's Avatar
Default Re: what valves to use for b16a1? (wreckedhatch)
or ITR
Old Sep 1, 2002 | 05:20 AM
Monty's Avatar
I used 94 del slow valve guides, and seals in mine. Valves will work also.
hth,
Monty
http://www.norcalcrx.org
Old Sep 1, 2002 | 11:24 AM
Default Re: what valves to use for b16a1? (Monty)
what engine did you get the valve guides and valves out of. i know you said the del slow but is it the b16a del sol or is it the d16z? please let me know. thanks
Old Sep 1, 2002 | 11:30 AM
Losrocket_'s Avatar
ITR valve train would work great unless youre planning to rev out to 9500 RPM or higher but for a normal application theyd work fine. Just a thought.
Old Sep 2, 2002 | 06:18 PM
Monty's Avatar
I replaced with b16a3 del slow ones. 94-95
I only wish I had the money for ITR valve train / cams (600-1000 + labor), or Skank 2
Old Sep 2, 2002 | 06:45 PM
Brandon Chun's Avatar
ITR valvetrain you can find some type r owners selling theirs for a good price.
Some people would say portflow inners, r outers for the springs.
GSRVTEC1
Oct 31, 2005 01:19 PM
Tad
20
Aug 26, 2004 04:31 PM
menkio
Jul 23, 2004 12:27 PM
redciviclx14
Jul 2, 2003 07:31 PM
