D16Z6 Turbo Engine No Turbo All Nitrous Questions....
I have the opportunity to buy a built d16z6 however I dont want to turbo it just yet. I originally wanted to build one exactly like the one I am looking at except a Bisi Nitrous cam instead of a stage 2 Crower and some high comp pistons instead of the 9.1:1 JE's that are in it. I plan on running E85 this time around and with the low comp the timing would probably be about maxed out I guess on the low comp. How well would the turbo camshaft work with nitrous? How much gas can I put on this thing?
Engine:
D16Z6
75.5mm JE 9.1:1 Turbo Pistons
Eagle H-beams w/ ARP 2000's
Block Guard
Head:
All Crower Valvetrain
Stg 2 Turbo Cam
I already have 160hp wet on pump gas on a stock JDM D15B so I was thinking 250 or so worth of gas? Will the sleeves take that in two systems 150-100 both wet of course?
Derek
Engine:
D16Z6
Block Guard
Head:
Stg 2 Turbo Cam
Derek
The Bisimoto Turbo Camshaft will actually work very well when using nitrous. While it may not be optimized, you will still see gains over the stock set-up. When you finally get the turbo system set-up,you will already be set in the cam dept.
JUST2SPOOL
Feb 8, 2006 05:06 PM
