serial number on b16a1
Old Aug 31, 2002 | 03:20 PM
chirp2hrd's Avatar
Default serial number on b16a1
how do i know if my block is a jdm b16a1?? is there a way to check the serial number on it?
Old Aug 31, 2002 | 03:40 PM
SpeedMonkeyRacing's Avatar
Default Re: serial number on b16a1 (chirp2hrd)
if it says B16A and not B16A2..you have a jdm b16
Jeff-
Old Aug 31, 2002 | 03:56 PM
chirp2hrd's Avatar
Default Re: serial number on b16a1 (Corporal-Jeff)
so if its first gen b16 it will just say b16 what about the serial number how can i check it to see what it comes up as
Old Aug 31, 2002 | 04:14 PM
i don't think it comes w/ vin number...NOR there are any 1st gen b16 that's USDM. but if you really want to tell the different..the hybrid site tells you where to look for.
Jeff-
Old Aug 31, 2002 | 04:22 PM
chirp2hrd's Avatar
ohhhh what hybridsite
Malgerus's Avatar
"Dohc" is bigger than "Vtec", the electrical connectors are a different colour, ( not sure which is which". You can also tell if it came out of a CRX SiR or Integra X-Si/R-SI by identifying the code that is around or below "B16" if it starts with 5 million, I believe you have an SiR engine. 1 million and it's an Integra model. Also, if you have an S1 transmission with it, chances are it's an Integra... that's what the S1 tranny came in over there.
Old Sep 1, 2002 | 05:31 AM
Monty's Avatar
You can also check the year of your engine. Its stamped in a circle right above the header. It will only have the last two digits ie (90) If its below 93 its definately jdm.
In most cases the stamp will be one year earlier than the car it came out of.
If you had a 92 5 million its jdm
93 4 million would be US
hth,
Monty
http://www.norcalcrx.org
Old Sep 1, 2002 | 10:37 AM
LoneStarCRX's Avatar
Default Re: serial number on b16a1 (Monty)
Is there any advantage of one over the other? Or are they identical?
seldon
Transmission & Drivetrain
Dec 3, 2008 10:13 PM
m0use
15
Jul 2, 2006 05:27 AM
1991hondahead
Sep 6, 2004 10:59 AM
joeyandhiscrx
Mar 10, 2004 03:31 PM
T_Rex
Sep 7, 2002 10:04 AM
