88 civic antenna alternatives
ok so im going to get the body work done on my 88 hatch then im going to get it painted suzuka blue. but im thinking of covering where the antenna goes to make it look like it was never there but when i install a radio i know i need an antenna but dont know wich ones to go with but like nothing fancy just something that can pick up more stations than a regular one like kday thats the ish 93.5 but yea please tell me the alternatioves thanks
This is the one I am using when i shaved my antenna hole...just run it through your A pillar and stick it on the top of your front windshield. Works like a charm, I pick up very clear fm/am signal when I am using my radio
http://www.amazon.com/gp/product/B000B9E3QM
i c it has for 2 plugs whats the other one for? do i need the old antenna for parts? do u have pictures big dog of how it looks with out the antenna thing thanks
The connector on the antenna looks like this and plugged right into my aftermarket radio...
I don't remember what stock was but fairly certain it was the same connection type...the other is just a wire to amplify the signal even more...as in you connect the wire to a 12 volt source, such as the power or ignition to your radio.
ok so its only one plug.
the one behind the radio only.
int the first link u sent it looked to be as if there wer 2 plugs thats why. and that black round piece where you hide that? and do you have to buy the 2 other sticks it shows there?
yes the one behind the radio only. their is that plug pictures above and just a simple wire. And no you don't need to get anything else, the other "sticks" it shows are adapters for cars that have a different antenna plug on the radio.
Once you plug the antenna in to your radio, you run it up through your A pillar and then stick it on your windshield (comes with 3m double sided tape already attached to the lil rectangular box looking thing) this way it is out of the way and barely noticable and able to receive a good signal
so rectangular piece goes on the driver side pillar but towards the top where the headliner starts right?or run it up the pillar and tape it inside some how?
I also filled in the groove that goes along the entire top of the roof near the edge, as well as the antenna hole...so your's may still look a little different.
Yea I ran mine on the passenger side though, poked it through where your headliner and A pillar ends at the top and then stuck it on the windshield. you could probably get away leaving it under your dash somewhere but may not receive as good a signal.
ok kool thanks man and looks clean cant really tell but looks like u shaved the roof moldings too damn lol yea im going to leave them, it has a lil rust but nothing bad or major. im going to get new roof moldings with the clips from online dealer like 35 each with clips new quarter window clips and screws from online dealer im going to put new window and door gaskets led lights on my cluster sick haha cant believe all im going through but will def be worth it at the end haha and imagine suzuka blue ***** rare im always lookin in the road for one and nothing haha imagin a hatch haha sick to excited. last thing i was even thinking of painting it b90p supersonic blue but naw i think it would look cool but idk rather something smooth
doing the same work and how long is that cord i want to hide the antenna at so i was thinking of running it all the way to the rear some where all help is appreciated
