What timing do you run on your stock type r? as well as flywheel questrion
U sed to have a GSR motor with Type R cams and skunk manifold. Now that has blown up and I now have a legit type r motor from a wreck.
Can you tell me what timing you arfe running. Mine is at stock 16 degrees right now but I am running a skunk2 ecu. The car feels much slower than my GSR and I am wondering of it could be because the timing is not advance enough or if it is the stock type r flywheel vs my GSR lightened flywheel.
Any answers would be great. I would advance my timing a bit but want to see what everyone else is using.
Thanks,
AW
[Modified by AW, 5:19 PM 8/31/2002]
Thanks,
AW
18deg with I/H.
GSR flywheel is quite a bit heavier than ITR one. Isn't it 16lbs for GSR flywheel? ITR one is ~12-13lbs, I think.
18 here, and I <u>can</u> tell the difference, in combination with the other mods.
GSR flywheel is heavier than ITR but my GSR was lightened about 8 lbs so it was much ligfhter than an stock ITR flywheel. My car does not rev as easily as it did before. I may have to change to a lighter flywheel again. I thought the ITR flywheel would have been lighter than the stock GSR by a lot but I guess it isn't.
I guess I will have to up the timing but I will try my Skunk2 ecu at the track first at 16 and then up it if it is not enough. I think the Skunk2 ecu advances the timing alot but not sure by how much...
Did you try swapping the Skunk2 ECU out and putting the stock ECU back in? Off-the-shelf ECU's seem to be hit or miss when it comes to actually performing better.
Actually the ecu works great. The problem I have is that because my old flywheel was much lighter I could rev the car quicker than I can now. Surprisingly, the 5-6 lbs difference is flywheel is weight is huge. Now what to do, put in my old lightened GSR flywheel or get an aftermarket one that is even lighter?
AW
AW
MikeSarr_GSR
Jul 20, 2003 09:21 AM
ITS BONE STOCK I SWEAR
Jul 5, 2001 12:56 PM
