ef sedan ksport conundrum!!
Old Nov 10, 2009 | 07:12 PM
nukefivesix's Avatar
Default ef sedan ksport conundrum!!
ok ive been looking hard for some real coilovers for my car, i found a set of fresh ksport kontrols for an eg/dc2 chassis for a killer price, they will be going on a 1990 civic sedan.. ive been told the rears are the same, but i will need to swap out my front lcas and forks.. does anyone have any idea if i can make them work.. i have alot of parts lying about to make this happen.. thanks!
Old Nov 10, 2009 | 07:23 PM
90_EX_Civic's Avatar
Default Re: ef sedan ksport conundrum!!
it'll work, and yes you'll need the front forks from a eg/dc. the part of the fork that the shock goes into, the hole for the eg/dc is bigger then the ef's.
Old Nov 10, 2009 | 07:34 PM
great.. what about the lca.. i think its wider on the bottom of the fork, and are the rears realy the same?
Old Nov 10, 2009 | 07:53 PM
it might be a little bit off, but that as much as the front.
Old Nov 10, 2009 | 07:58 PM
ef yu's Avatar
i have put eg shocks on my crx before. all i did was swap out the forks and that was it. did not need to change any lca for it. hope this helps
Old Nov 10, 2009 | 08:19 PM
cool.. good to hear it.. so front and rear will work? and all i should need to do is forks up front?
Old Nov 10, 2009 | 08:46 PM
~sp33~'s Avatar
EFB055
Yup.
Old Nov 10, 2009 | 08:49 PM
sweeeeeeeeet! well im off to fianally give my car the stance it deserves
edit.. will a rear camber kit for a dc2 work as well?
Old Nov 10, 2009 | 10:02 PM
Driven's Avatar
...why not just go with the tried and effective koni/gc combo? Rather than piece-mailing suspension that isn't as good?
Old Nov 11, 2009 | 02:24 AM
alexEF's Avatar
yeah! Koni/GC combo!
Old Nov 11, 2009 | 03:00 AM
~sp33~'s Avatar
EFB055
Maybe he can get the dc2/eg setup for cheap.
Old Nov 11, 2009 | 12:22 PM
EJ1_Sleeper's Avatar
what do you mean? Any full coilover beats a sleeve setup, even if its GC/koni setup. You get to keep the full shock travel and drop the car as low as you want. Now if these coils are used and dont work then hes screwed, but other than that full coilovers anyday of the week.
Old Nov 11, 2009 | 05:55 PM
machine4321's Avatar
No no it does not beat "sleeves". Konis probly have the best dampers out there for the money. A koni damper with the right spring rate will destroy any of the china/tiwan full coil overs any day...as well as last longer. The full setups are great for the money and they look really pretty but there is a reason a real full coil over setup cost 3x as much as the ksports ect.
Old Nov 11, 2009 | 06:53 PM
88Hatchy's Avatar
exactly
EF9 PRIDE
Suspension & Brakes
Aug 15, 2014 03:40 PM
rexracer626
Jun 11, 2010 11:31 AM
724chris
Dec 16, 2009 10:47 PM
evosix
Suspension & Brakes
May 31, 2007 09:13 AM
Lo-Buck EF
May 8, 2003 04:34 PM
