rex wiring ???
Old Nov 10, 2009 | 10:57 AM
8dxhatchy8's Avatar
Default rex wiring ???
okay....its a 90 rex dx, theres two wires on the back of the block...above the oil filter with like a rubber cap covering the two female ends of the wires...ones yellow with a green stripe the others black, does it matter where there plugged in or can they be switched and not affect anything??? as in left or right or vice versa........thanks
Old Nov 10, 2009 | 11:01 AM
fin781's Avatar
Default Re: rex wiring ???
id love to say its a coolant temp but im 2% sure lol. there was a thread on this a while back. google engine block sensors on that engine and click images it might help u
Old Nov 10, 2009 | 11:22 AM
D16SiHatch's Avatar
it's your coolant fan switch. it doesn't matter which wire goes where.
Old Nov 10, 2009 | 11:40 AM
8dxhatchy8's Avatar
awesome....thanks bro..
Old Nov 10, 2009 | 12:14 PM
8dxhatchy8's Avatar
damnit....why isint my main relay clicking, and i know its good for a fact, im getting no fuel pump prime or anything......AAHH.so irritating!!
Old Nov 10, 2009 | 03:46 PM
hisnibs's Avatar
Test your ground at the Thermostat and frame rail.
Do you have 12 volts at the battery?
Old Nov 10, 2009 | 04:55 PM
8dxhatchy8's Avatar
yep all grounds and connections are good....
Old Nov 10, 2009 | 06:34 PM
8dxhatchy8's Avatar
are the injectors powered by the ecu? or grounded by the ecu?
Old Nov 12, 2009 | 10:54 AM
8dxhatchy8's Avatar
ok...so i did c1 and c2 over to b10 and b12, ran c1&2 into the engine bay, hooked em up, did A3 and A7 for the injectors also hooked them up.....NOW the two yellow/black wires that were with the injectors, i hooked them to the resistor box but they do nothing, after testing them, when i touch them to a hot wire they turn on the fuel pump??
any ideas whats goin on? i need serious help here........
Old Nov 12, 2009 | 12:07 PM
4drEF's Avatar
Keyboard Humorist
The 4 yellow blacks are supposed to get 12v.
It sounds like when you hook it to 12v then it's sending power to the injectors AND feeding back through to the main relay.
I wouldn't doubt it if your car starts if you leave 12v to the ECU side of the resistor box.
Do NOT hook 12v direct to the injectors... it needs to pass through the resistor box or else you risk frying the injector.
My guess is that your 12v supply to the main relay is bad.
Old Nov 12, 2009 | 02:13 PM
8dxhatchy8's Avatar
i know that....but the stock 2 yellow/black wires that went to the stock dx injectors.....where do they go? and whats there purpose??
Old Nov 12, 2009 | 02:23 PM
4drEF's Avatar
Keyboard Humorist
Their purpose was to provide the injectors with 12v (not ground).
They run straight to the main relay.
Check fuse in your fuse box under the hood to make sure your main relay is getting power.
Old Nov 12, 2009 | 02:33 PM
8dxhatchy8's Avatar
i used a tester light and the harness is getting power at the main relay, the ground is also good at the harness, i pulled a relay out of a running car too just to see if that was the problem and still nothing.......i just dont get it
madgeo
Aug 1, 2010 11:33 AM
Master23
Jun 23, 2009 04:32 PM
D50boy
Aug 26, 2008 10:00 AM
tibss
Jan 31, 2008 11:28 PM
kagegod
Jun 23, 2004 08:10 AM
