Ever took harness out your ef hatch?
Well I gotta get a new one really just under dash part wanted to know do I have to pulled the whole harness from front to back?Or is it two different harnesses?
It's not too bad a job to pull and reinstall the harness really.
The PITA is dealing with all the carpet and firewall insulation.
Also if you need to replace the dash harness, it includes all the wires under the hood ie headlights, turn signals, wiper motor and HVAC.
Yea thats the one I have to take out.
There are different harnesses for our cars.
1. Engine harness
2. Under dash (cluster, radio, clock & climate control)
3. Cabin harness (fuel pump, tail lights)
4. Main harness (ecu, head lights, wiper motors under dash fuse box)
5. A/c harness
6. Door harnesses
to get to the headlight harness you will have to get the ecu harness
1. Engine harness
5. A/c harness
6. Door harnesses
1. Engine harness
5. A/c harness
6. Door harnesses
1. Engine harness
5. A/c harness
6. Door harnesses
If I only need the headlight harness can I cut it under the hood and wire just that part of the harness instead of buying a bunch of garbage I don't need? My drivers side headlight caught on fire and roasted the wiring.
Yes! It is possible to repair a main body harness from under the hood instead of replacing from under dash, I spliced each wire and used but connectors and shrink wrapped, performed a little crimp action, and boom saved myself 500 bucks at Honda. Looks a little intimidating at first but just pay close attention to the wire colors and markings. Good luck but hope no one has to go through that.
Oscarasimov
13
Sep 19, 2012 10:33 PM
V/\ freestyle
Mar 13, 2011 08:52 PM
