Suspension & Brakes Theory, alignment, spring rates....
Grade 5 bolt strong enough for suspension
Old Nov 8, 2009 | 01:26 PM
a97b18b's Avatar
Default Grade 5 bolt strong enough for suspension
I need to know if a grade 5 bolt is strong enough to hold the strut on the lca. That's the only bold the store that I went to had and I needed one fast so thats what I got till I could find a higher grade or find out if it was ok.
Old Nov 8, 2009 | 03:17 PM
dandaman15's Avatar
Community Builder
Default Re: Grade 5 bolt strong enough for suspension
I should think so, many people wouldnt even care what grade they have and go to a place like Home Depot and get ungraded ones. Grade 5 is much better than ungraded and I dont hear many problems with ungraded ones.
Old Nov 8, 2009 | 03:18 PM
fastrxu's Avatar
Grade 10 for suspension. Thats what mr. Wong from ASR told me to use when i had some issues with the hardware for the subframe.
He said anything inferior could snap specially under spirited driving, or autox. I dont know how you drive but 5 sounds potentially dangerous
Old Nov 8, 2009 | 05:09 PM
kommon_sense's Avatar
strut to lca bolt carries a significant load. oem or better...
Old Nov 8, 2009 | 06:24 PM
a97b18b's Avatar
If I can find an oem one that's long enough I'd prob get that. But I think I'm just gonna go to home depot tomorrow. Pep Boys just had the grade 5 that was long enough and I needed something to get my car home. I had to drive like 40 miles tonight and I was worried the hole time. Luckily the highways here aren't too bad. First thing tomorrow is deff a stronger bolt. Even if it is strong enough I don't feel safe w/ it.
So it's either grade 8 or 10.9 right? or higher obviously
Old Nov 8, 2009 | 06:41 PM
STOCK_SOHC_DX's Avatar
10.9 for anything that is load bearing. Especially suspension bolts.
Old Nov 8, 2009 | 07:02 PM
home depot sells crappy bolts to hold your deck together. go to a hardware store like an ace hardware. They have a wide selection of grade 10 bolts.
Old Nov 13, 2009 | 10:39 PM
thumper64's Avatar
the 10.9 is metric and according to the site posted above, it sounds like it's equal to our SAE grade 8 bolts.
I've ran grade 8 hardware on my suspension and even with spirited driving and jacking the whole rear up by one LCA, none have snapped thus far. I'd rather have all batch tested hardware and such, but I'm broke.
Old Nov 13, 2009 | 11:41 PM
racebum's Avatar
correct. the only thing stronger would be to ream the hole {if you even could without getting into bushing} and use a larger grade 8 bolt or move to something that fits with a nut from ARP.
in order to break a grade 8 bolt you would need a LOT of spring rate and a very quick hit on the arm. even then it's hard to imagine. i remember jumping a stock integra over some fairly steep railroad tracks at 110-120mph. came down, totally bottomed the suspension and ripped a big chunk of the front tires on that seam in the fenders. no broken bolts.....
Old Nov 14, 2009 | 05:57 AM
alphalanos's Avatar
what about a junk yard?
Old Nov 14, 2009 | 08:11 PM
a97b18b's Avatar
what about a junk yard??
I did replace the bolt w/ a grade 8. w/ the other bolt i wasn't at ease w/ having it so I knew I couldn't keep it in for long
Old Nov 29, 2009 | 02:40 AM
fastrxu's Avatar
110-120mph? Railroad?
I saw that movie!
LavishTheKid
Jan 1, 2011 09:40 PM
Xerxes3333
Aug 2, 2004 06:24 PM
jagged4698
Mar 8, 2004 07:26 AM
BrynnTheSlut
34
Aug 16, 2003 01:44 PM
sjteg
Jun 16, 2003 11:13 PM
