vtec not working on gsr in eg
Old Nov 7, 2009 | 09:58 PM
Your Name's Avatar
Default vtec not working on gsr in eg
i just did a auto to manual.
and a obd1 gsr swap.
in a eg..
vtec is not working. its on a stock p72 ecu. and everything is pluged in.. dose it have a to grounded? do i have to wire vtec in?
Old Nov 8, 2009 | 12:27 AM
freshvibes's Avatar
Default Re: vtec not working on gsr in eg
Did you run wires from the solenoid to the ecu?
Old Nov 8, 2009 | 12:29 AM
ekb16a's Avatar
u have any codes ?
did u wire up corecly
Old Nov 8, 2009 | 01:53 AM
joker_x's Avatar
check the engine oil level, vtec solenoid, or the crank sensor
Old Nov 8, 2009 | 05:02 AM
batallic's Avatar
in a eg..
thats y yur vtec isnt working its wired up, wire it up, what car
Old Nov 9, 2009 | 11:11 AM
Your Name's Avatar
how do i wire it up?
Old Nov 9, 2009 | 11:33 AM
batallic's Avatar
http://www.google.ca/#hl=en&source=h...16e92003ac2179
Old Nov 10, 2009 | 07:33 AM
mrharmonic's Avatar
run a p28 :D thats what im runing on my eg works fine
Old Nov 10, 2009 | 08:23 AM
B18CivicEJ8's Avatar
Dude, he has a stock GSR with probably a stock intake manifold. The p28 is for a SOHC vtec motor and doesn't have the circuitry to deal with his intake air bypass valve, nor does it have the circuitry to deal with a knock sensor. He already has a stock p72 ecu, he just needs to run a wire to the solenoid. How is buying a whole new ECU and then getting it chipped with GSR basemap going to help him if VTEC isn't wired up?
Old Jan 17, 2010 | 05:11 PM
poor mans si's Avatar
New User
hey i have a 99 si ( legit em1) i put a gsr bottem end and 99 si head with ctr pistons in it. the car runs great but vtec doesnt work. theres no cel and theres plenty of oil. ive had the head apart and everything is in working condition, when i put a obdi jumper and ecu i get a code9
Old Jan 17, 2010 | 07:10 PM
American.Graffiti's Avatar
A few months prior I did the same exact thing to my car except with a p28 ecu. Plug up your vtec sel. If I am not mistaken there is one blue wire (which goes to the ecu) and one black wire (which is ground). Find the according pin on the ECU (what I ended up doing was cutting one that was being used for the gear selection indicator, put it into the plug on the ecu where the vtec pin was located, and ran it straight to the sel). It worked perfectly the first time for me.
Old Jan 17, 2010 | 08:07 PM
mrharmonic's Avatar
exactly so stfu ej8 and american i did the samethig and have had never had a problem with the p28. the only thing diffrent on a gsr head is the butterflie witch have nothing to do with the air bypass valve
redlineEGhatch
18
Jun 10, 2014 05:52 PM
molosect
Oct 12, 2005 11:32 AM
Lookincrazy
Apr 21, 2002 10:11 AM
