HID question
Old Nov 6, 2009 | 10:22 AM
dxlol's Avatar
Default HID question
i was told by a friend that if I wanted to upgrade my lights to HID's I would have to get different headlight housings because it will melt the plastic. Is this true? I only want to run 8000k kit. please help.
thanks.
Old Nov 6, 2009 | 10:39 AM
civicjunkie17's Avatar
Default Re: HID question
if you install it correctly you'll be fine. just pay attention to how you take your stock headlights out.
Old Nov 6, 2009 | 11:10 AM
sde780's Avatar
You will blind the crap out of incoming traffic. Look in the lighting forum, research HID projector retrofits
Old Nov 6, 2009 | 11:16 AM
Duc_du's Avatar
it will most likely melt if use in a cheap ebay headlights. havent seen but that is what i was told. OEM headlights should be fine
Old Nov 6, 2009 | 11:25 AM
95jdmcivic's Avatar
Guys! HIDs run cooler then Halogen, so how in the hell is it going to melt the housing if your halogens didnt. Common sense and lots of wrong information going around.
Old Nov 6, 2009 | 12:50 PM
boxeocampeon's Avatar
it should be good if you have factory headlights
Old Nov 6, 2009 | 12:52 PM
4gnhatch's Avatar
ive never had a problem with mine and ive had mine for over a year not even the ballasts just my 2cents
Old Nov 6, 2009 | 01:31 PM
NOOdS's Avatar
i have HIDs on my OEM CTR headlights. why are people so scared that the bulbs will burn your headlights? idiots! dont listen to people who dont even have them.
Old Nov 6, 2009 | 01:49 PM
EJ8Bramaged's Avatar
I had projectors in my previous car and on the housing it even said not to install HID KIT. So I did it anyways, and I didn't have any problems. The lense of the headlights weren't NEAR as hot as the halogens.
It's like the "turn off your cell phone" at the gas pump MYTH. Even the retailers believe the crap sometimes.
Old Nov 6, 2009 | 03:25 PM
mattyfo0z's Avatar
No, it won't melt your headlight housings. But you will blind everyone driving in front of you as well as going the opposite way of you with your crappy PnP HID kit. Oh, and you're a ricer.
Do it once, and do it right: get a retrofit or stick to Halogen bulbs.
Old Nov 6, 2009 | 04:17 PM
dxlol's Avatar
so in order not to blind the hell out of incoming traffic, I need to upgrade from stock housings and lenses? sorry, just a little confused after compiling all of the info.
Old Nov 6, 2009 | 05:03 PM
runtohell121's Avatar
You have to retro it in order to prevent blinding others.
Old Nov 6, 2009 | 05:33 PM
hondaridaa's Avatar
by the plug and play kits and youll be straight
Old Nov 6, 2009 | 07:29 PM
miguel329's Avatar
im on "doit once! doit rite idea" but, ive had no issues with my plug and play kit. noones flashed me... i think people on here just want to cry about anything.. ive gotten flashed in my wife's fit when i forget to turn high beams off(with have stock light) but my eg hatch has pnp kit and i havent had one issue....i even pass cops all the time and they are dicks around here and havent had a problem...
Old Nov 6, 2009 | 07:48 PM
FRESHTEG's Avatar
its just plug and play they wont melt and best light output are the 4300 or 5000
Old Nov 6, 2009 | 08:02 PM
mattyfo0z's Avatar
Here's what a PnP kit looks like when it's coming toward you (it said it's 8000k; Google image search):
...and here's what it looks like when you're driving:
Finally, what it's supposed to look like:
See the difference? Don't be a ricer, and don't waste your money on rubbish HID kits.
Old Nov 7, 2009 | 09:10 AM
retrosolutions's Avatar
It is true that HID run cooler than the stock bulbs, even so for our 55w kits.
So why do the ebay lamps melt with HID you ask?
The quality of the optics is so bad, so improperly designed, that the incorrectly focused intensity of the HID ouput melts the front of the lamp or the bezel next to the projector. OEM projector lamps can run HID all day and not do this because there is actual research and development put into those products. That is why a single OE lamp costs twice as much as an ebay pair of projector lamps.
Old Nov 7, 2009 | 09:15 AM
00EckoSI's Avatar
i bought my kit from VVME.Com on my old car and have had no problems what so ever with it was plug n play with 10000k bulbs
Old Nov 7, 2009 | 01:21 PM
98civdx's Avatar
Master Detailer
wrong, i have cheep ebay lights with hids for almost a year and they are just fine, and several of my friends do as well.
Old Nov 7, 2009 | 01:25 PM
mortificationrock's Avatar
The CLASSIC
PnP Vs. Retro ****!
Buy what ever makes you happy. And what you can afford. Not many people are capableof opening their headlights up and doing all that work. Plus the gang of $ behind it also.
Old Nov 7, 2009 | 01:32 PM
dxlol's Avatar
thanks everyone for all the input. I've been reading up on the lighting forum and I should have my new setup on soon!
Old Nov 7, 2009 | 02:50 PM
Duc_du's Avatar
um okay i just say that is what i hurd and never witness it BUT
Even this guy say so and i remember somebody on here complain that it did melt their lamp so they had to get a new one. i guess it just the material that the makers use.
Old Nov 7, 2009 | 05:45 PM
98civdx's Avatar
Master Detailer
The things is hids run cooler then normal lights.
I have NEVER heard of anyone melting lights with hids
Only when guys run like 100 watt bulbs
Old Nov 8, 2009 | 06:43 AM
Just to add more fuel to the fire, yes, we've seen melting with ebay lamps, we also have many clients running our 55w kits in similar ebay lamps with no problems. It does vary from model to model of lamp. Our recommendation is never to goto the ebay lamps unless you know someone else is running them with actual decent output.... because many go int he opposite direction.
Old Nov 8, 2009 | 08:48 AM
98civdx's Avatar
Master Detailer
my output with ebay lights with silverstars sucked, thats why i went hids, but my ebay lights with hids, are 10 times better them my buddy with oems and hids, not saying mine are perfect but he throws out a lot more glare.
also op dont run past 6000k
