Difference between B16 and B18 LMA's?
Is there a difference between B16 and B18 LMA's? I'm just asking becaus Honda sells them cheaper than Acura by a buck and some change. I should just be able to buy them from Honda and they're universal to all B series VTEC cylinder heads, right?
i know every place iv shoped around for em they do have a diffrent selection when buying them.( make you choose B16, B18 etc). so i think they may be diffrent but im not positive.
Are they the same part number? I also remember seeing a thread about H22 LMA's fitting B16's if they are reversed or something like that. And they're alot cheaper. Try searching for that
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/%2Anew%2A-b-series-lma-info-2312727/
This thread makes it seem like all B vtec heads use the same LMAs.
However, no personal experience here.
Thanks guys, I can't compare PN's because they differ between Honda and Acura, I guess best thing to do is buy a b16 head and compare with my gsr ones. But I'll do some research and see what I come up with.
sorry for bumping an old thread
I found on Unlimited Honda / Acura
99 Si use 14820-P30-010 22.25 ea
ITR use 14820-P73-J01 33.79 ea
Different Part number..??
