The starter motor works but the car won't crank
Old Nov 5, 2009 | 10:40 AM
clikoyl's Avatar
New User
Default The starter motor works but the car won't crank
I tried cranking my car today and when I turned the key nothing happened. I got the stater used and thought that was the problem but when I connected the negative and positive on the starter the car cranked then stalled out. I checked the battery connections and the starter relay fuse and they were fine. Is there any fuse or connection that I'm missing or could I have an ecu issue?
Old Nov 5, 2009 | 10:49 AM
Former User's Avatar
Default Re: The starter motor works but the car won't crank
There is a starter switch located at the top of the clutch pedal. If it's bad, the starter won't crank the engine using the key.
Old Nov 5, 2009 | 12:50 PM
shogee's Avatar
on the starter there is a little solenoid, it's a little wire that goes to the starter, get a test light and hook up to that wire (its only one wire), and ground, have someone turn the key to crank if light comes on it is the starter, you got a crappy one from the junkyard, if light dont come on the check the switch like ron says
Old Nov 5, 2009 | 01:01 PM
Originally Posted by clikoyl
...when I connected the negative and positive on the starter the car cranked...
I think his test shows that the starter is fine.
nestea8869
10
Mar 26, 2022 10:12 AM
killaberna
Sep 9, 2015 07:56 PM
JJT211
Jun 22, 2014 08:33 PM
eg_beast
May 4, 2009 04:57 AM
ghost_ryder35
Sep 7, 2005 05:53 PM
