<>Offset Help!<>
Old Nov 4, 2009 | 08:31 PM
thomasw91's Avatar
Default <>Offset Help!<>
Old Nov 5, 2009 | 06:02 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: <>Offset Help!<>
Offset doesn't lower a car. It determines how far the wheels stick out from the car.
Old Nov 5, 2009 | 06:34 AM
mattyfo0z's Avatar
Those wheels you linked to and the wheels in the picture you posted are pretty different.. which are you getting? I don't think the wheels in the picture are too hot, especially because they look huge on that hatchback.
Old Nov 5, 2009 | 01:08 PM
thomasw91's Avatar
The black hatch is my car currently. I'm wondering if those enkei's with the offset 38 are good for lowering a car and i know offset doesn't lower a car.
Old Nov 5, 2009 | 04:45 PM
DumaDA's Avatar
38 offset isnt very low, and its only 7" wide, they'll probably be sunk depending how low you go
Old Nov 5, 2009 | 05:09 PM
Dilly's Avatar
Originally Posted by fwdtamiya
Offset is the distance from the center line of the wheel (in an 8 inch wheel, it's 4 inches) to the back of the mounting hub
The lower the number in offset, the closer the wheel moves toward the fender and away from the shock tower.
Another term synonymous with offset is backspacing. Backspacing is the distance from the rear of the hub to the end of the wheel toward the shock tower; most easily measured by laying your wheel face down, putting a straight edge accross the wheel and measuring from the hub out to the straight edge.
here's a link for more info on that
http://www.tirerack.com/wheels/tech/...jsp?techid=101
and here's a backspacing to offset chart
Offset is measured in millimeters
1 inch = 25.4mm
When you go +1 inch in width from your current setup 12.7mm is added equally to both sides of the wheel from the hub, so a 15x8 +30 will stick out 12.7mm more than a 15x7 +30.
Here's a basic offset calculator
http://www.1010tires.com/WheelOffsetCalculator.asp
Here's a more in depth one that I prefer to use (note: you can't stretch tires)
http://www.rims-n-tires.com/rt_specs.jsp
Old Nov 5, 2009 | 08:28 PM
dunkXdrift831's Avatar
don't go higher then a 38-40+ offset. if your goin to slam it and want it flush then you will need camber arms.
Old Nov 5, 2009 | 08:31 PM
DumaDA's Avatar
if you want it to look good and you're gonna be slammed, go with like 15x7 +20, my 15x7 +10 are sunk in but thats cause its on a DA, on an ek it would be more flush
Old Nov 6, 2009 | 08:40 AM
DrZFiNeSt's Avatar
You shouldn't have any rubbing issues with a +38 offset
HamiltonRex
Oct 12, 2005 11:56 AM
torqueless
Jul 13, 2005 12:12 PM
silver_nteg
Jan 6, 2004 11:02 AM
JoeyBallzSI
Oct 20, 2003 03:04 PM
Yogi bear
Jun 29, 2001 08:20 PM
