d15b2 to d16a6 what do i need
ok i have a 91 crx si and im swap everything from my si rex to my hf crx i have because shell on si is bad
but i need to know what i need to swap the d16a6 for the si into the my other rex with the d15b2? do i just need the motor harness from the d16? will it bolt on to the other rex main car harness with the d15 because theres a extra plug on my d16 main harness that the d15 dosnt have? or do i need to change the full car harness? thankz
Search man, search.
I'll give you a hint. "MPFI swap." How will you ever learn if all you ever do is get answers spoon-fed to you?
All the information is out there, it's been covered well over 10,000 times. Put in a bit of effort next time and you'll be amazed what you find.
but i need to know what i need to swap the d16a6 for the si into the my other rex with the d15b2? do i just need the motor harness from the d16? will it bolt on to the other rex main car harness with the d15 because theres a extra plug on my d16 main harness that the d15 dosnt have? or do i need to change the full car harness? thankzi don't give the best info, someone will pick this up, and point you in the right direction.
Crx_Daniel
Feb 6, 2013 01:01 PM
CJ407
Jul 17, 2008 01:47 AM
crxb18a1
24
Aug 14, 2004 05:39 PM
