Question about aftermarket seat brackets
Old Aug 30, 2002 | 08:29 PM
xjohnx's Avatar
Default Question about aftermarket seat brackets
How do these bolt up? I see how they bolt to the seat part, but i don't see how they bolt to the floorboard since the holes are angled in a way that there's no way these would bolt up? do you use the stock bottom part or something? Pics would be appreciated.
Old Aug 30, 2002 | 08:44 PM
norice's Avatar
Default Re: Question about aftermarket seat brackets (xjohnx)
You need car-specific brackets that mount to the floor. Sparco sell these for $50 a side (or $100 if you want seat belt mounts).
Old Aug 30, 2002 | 08:56 PM
xjohnx's Avatar
Default Re: Question about aftermarket seat brackets (norice)
Yikes..no other way to make'm work? that's unfortunate.
Old Aug 30, 2002 | 09:13 PM
Trooper's Avatar
Just wa warning , the sparco brackets need some adjustment usual. Mine had to be bent to make them fit.
Old Aug 30, 2002 | 09:16 PM
xjohnx's Avatar
Default Re: Question about aftermarket seat brackets (Trooper)
any other reccomendations (read: cheaper), seatbelt brackets a must.
Old Aug 30, 2002 | 09:17 PM
norice's Avatar
Sparco brackets suck and blow at the same time. However, they are pretty much your only option, unless you know a good metal fabricator.
Old Aug 30, 2002 | 10:13 PM
K1R's Avatar
K1R
you need Side Mount, Slider, Bracket.
Old Aug 30, 2002 | 10:19 PM
norice's Avatar
Default Re: Question about aftermarket seat brackets (Torque)
To be pedantic:
If you have base mount seats, you can attach the seats directly to the floor mount. Or you can use sliders in between the floor mount and the base of the seats.
If you have side mount seats, you need the side mount brackets, which can be attached directly to the floor mounts, which can also have sliders in between.
Old Aug 30, 2002 | 10:44 PM
underrated99si's Avatar
yep yo need all of these and then have them botled together or in my case weld them for strengh I have the same set up going in my car evo and thos same harnesses just waiting for the side bracket to come in.
ZCHondaCRX91
Welding / Fabrication
Jan 12, 2012 05:33 PM
117
Jan 5, 2005 05:20 PM
RineRacing
Jun 16, 2003 11:56 AM
auto-x
Jan 25, 2003 11:54 AM
C-Murdock
Oct 31, 2002 04:33 PM
