What is the next step?? Pretend like its your car!!
Old Nov 4, 2009 | 08:30 AM
hannslebo's Avatar
Default What is the next step?? Pretend like its your car!!
I have a 95 civic coupe. It has a jdm b16 with I/H/E...6 puck clutch and a chipped p28 (no tune)
What would you guys recommend for the next performance upgrade??
please dont tell me..."its your car, do what you want." Im looking for opinions, thats why i said pretend its yours. Im kinda new to the honda world so thats why i do alot of these opinion threads, it doesent necessarily mean im going to do one or the other. anyways, any 2cents would be greatly appreciated.
thanks in advance
Old Nov 4, 2009 | 08:34 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Default Re: What is the next step?? Pretend like its your car!!
tune, then suspension.
Old Nov 4, 2009 | 08:36 AM
Archidictus's Avatar
Unceasing Measure
Stock Type-R Integra suspension with GSR swaybars.
azandford's Avatar
A good tune....i would suggest hondata s100 if not doing a turbo or s300 if a turbo is in your future. You will definently notice the difference with a good tune. A lightened flywheel. Also a skunk2 intake manifold will definently help. Avoid just throwing on a camshaft until you talk to your tuner as some aftermarket cams can be detrimental to power especially around vtec as opposed to a stock one.. Not in all cases but some. This question is hard to put a direct answer on since i dont know what your future plans are and what budget your working on. Definently do some reading aorund the forums and see what works best for other people and that will definently give you a good base to start from. But i would get a TUNE!
Old Nov 4, 2009 | 08:44 AM
hannslebo's Avatar
no plans for boost right now...maybe a small 35 or 50 shot. but that wouldent be until another year or so.
Old Nov 4, 2009 | 08:47 AM
Ass$nyper's Avatar
Pirate General...YARRRR
Tuning.
Then a large rear sway bar.
allenbarnette's Avatar
good suspension!
Old Nov 4, 2009 | 08:49 AM
Relic1's Avatar
1. tuning - find a reputable local tuner and ask them what they prefer to tune with. Go with that.
2. suspension
3. a little track time (track not strip)
4. more track time
5. replace tires
6. more track time
Old Nov 4, 2009 | 09:34 AM
boxeocampeon's Avatar
suspension then turbo or supercharger
Old Nov 4, 2009 | 10:17 AM
alphalanos's Avatar
tune, wheel/tires, suspension
Old Nov 4, 2009 | 10:27 AM
thumper64's Avatar
I'd lose the 6 puck, get a tune or at least base map chip, make sure the timing belt and BS is up to date, get suspension and brakes, then think about cams or something, last consider modding the interior or exterior.
Old Nov 4, 2009 | 10:32 AM
93egSLEEPER's Avatar
tune it, suspension, maybe build the head some and enjoy a fun car
Old Nov 4, 2009 | 12:14 PM
hannslebo's Avatar
thanks guys for the input...i guess tune will be next then more susp. i already have the ebay springs and some kyb shocks so i could still use some extra goodies for the suspension.
Old Nov 4, 2009 | 12:15 PM
sde780's Avatar
driver mod
Old Nov 4, 2009 | 12:20 PM
redrocket_ej1's Avatar
this http://cgi.ebay.com/ebaymotors/TEIN-...Q5fAccessories
Old Nov 4, 2009 | 12:26 PM
hannslebo's Avatar
those coilovers look very very nice...however i could never spend that much on something like that...im not really into the "slammed" hondas. Mine is not that much lower than stock, ive got over a hand width in the rear and about a hand width in the front...so i just do not need the most expensive susp.
they are very nice tho!!!
Old Nov 4, 2009 | 01:07 PM
thumper64's Avatar
Don't slam the car, it's not functional. Aftermarket or Integra springs (cheapest option) are stiffer and will make the car handle better. A little drop looks good, like 1-1.5" and gets a little negative camber.
Old Nov 4, 2009 | 01:23 PM
D Griff's Avatar
suspension and tires are next! autocrossing is a lot of fun... get some koni yellows and eibach springs or something like that
Old Nov 4, 2009 | 01:31 PM
fungus mungus's Avatar
Integra front discs, rear discs. That was probably the first thing you should have done. Then the tune. Then the suspension. No need to drop it more than 1.5".
fm
rotascircuit
Sep 10, 2008 07:55 AM
RC's ride
Dec 30, 2005 09:43 PM
hlee5363
Sep 26, 2005 11:57 AM
ekcivic9
Aug 23, 2005 06:55 PM
Ilouisell
Sep 18, 2003 01:26 PM
