Auto Vs Manual Engine
Old Nov 4, 2009 | 07:02 AM
eguti66's Avatar
Default Auto Vs Manual Engine
Hey Guys I found a replacement engine for my car but the guy says its from an auto. My question is Whats the difference between an engine from a auto trans and a manual trans car ? oh the car is a 1999 Honda civic ex
-Thanks
Old Nov 4, 2009 | 07:10 AM
nothing_shocking's Avatar
Default Re: Auto Vs Manual Engine
nothing
Old Nov 4, 2009 | 07:11 AM
Vindicator9000's Avatar
318 Curves, 11 miles
I believe the idle air control valves are different between auto/manual on 99-00 cars.
The automatic will have a flex plate rather than a flywheel. Beyond that, I'm not aware of anything.
Old Nov 4, 2009 | 07:15 AM
really? huh... then again, i've never really looked into automatics... will it make that much of a difference so long as he has the right computer?
Old Nov 4, 2009 | 07:21 AM
eguti66's Avatar
ok well i have a manual so i can swap everything over to the auto engine, I wasnt to sure if i had read somewhere that the intake or egr is different? i'll just have to see when i have the engines side by side
Old Nov 4, 2009 | 08:37 AM
Oh yeah, computer too. Forgot about that.
I remember reading somewhere that you have to repin the IACV from 2 wire to 3 wire or vice versa. Don't know for sure, I've never done one of these. Maybe it's possible to just swap the IACV from the manual engine.
Old Nov 4, 2009 | 09:30 AM
93 del slo's Avatar
automatics have 3 wires
Old Nov 4, 2009 | 09:54 AM
-__-'s Avatar
so all u have to do is re-pin or re-wire the IACV and throw the flywheel and clutch on the new motor.
u can run the Automatic ECU with some modification though
Old Nov 4, 2009 | 10:42 AM
thumper64's Avatar
Just swap the IACV. It's harder to screw up.
Converting the ECU involves clipping one resistor and replacing one with a regular strand of wire. It takes longer for my soldering iron to heat than to open it, do the work and close it back up.
Old Nov 4, 2009 | 12:26 PM
94EG8's Avatar
Seagull Management
Intake manifold is different, also throttlebody and IACV. Simply reuse your old stuff. Reuse your old IACV. So far as i'm aware you can't convert OBD2 ECUs from automatic to manual. You could do the OBD1 versions very easily in the way that thumper64 has stated.
Benchracer
Oct 10, 2008 11:50 AM
hany
12
Apr 21, 2007 12:43 AM
superturboprelude
Jun 26, 2005 05:38 PM
pierreram
Acura TL, RL & ZDX
Aug 8, 2003 10:21 PM
