Toooooooooooong!
is your spring bad or is it the door pin?if the hole around the pin is loose it will make noise.if the spring is messed up you can actually just change that.i think it's held in by 2 bolts.i might have a few extras from a parts car i will look if you need them let meknow.
th pin is supposed to not move.most of the time the whole gtes worn out on our cars.very common problem.i am gonna try to say if a machniist can make mea sleever to help fix this problem.if it works maybe i'll sell them cheap for everbody.
thats just the doors way of saying "Hi, fix me you bastard!"
haha
but seriously, about that Toooong noise....if you look at the door sill, you can see the "L shaped door open sensor". when you put the sensor in the closed position, there should be a screw you see...just loosen that screw a little bit to stop that thing from popping up......NO MORE TOOOONG
haha
beoy9
Jul 10, 2009 12:43 PM
E-lude78
Aug 31, 2002 09:31 AM
