Transmission & Drivetrain Gearboxes, Differentials, Clutches
Loose flywheel ring gear?
Old Nov 3, 2009 | 05:48 PM
thewrai6th's Avatar
Default Loose flywheel ring gear?
I picked up a resurfaced flywheel from a shop in San Jose, it always made bad sounds when starting. I pulled it off recently and found that the outer ring gear was loose. I tried to take it off and sure enough, it came right off.
What was holding it on in the first place? Just pressure?
My guess is that the flywheel was overheated at some point and the flywheel expanded, then contracted.
Old Nov 3, 2009 | 06:09 PM
sikkkkktegra's Avatar
Default Re: Loose flywheel ring gear?
its just tack welded.. mine broke off too just like a month ago. boooo
mlh996
Dec 24, 2017 11:22 AM
thewrai6th
Nov 2, 2009 08:44 PM
zman
Nov 16, 2005 04:37 AM
Manguish
May 6, 2003 07:07 AM
