Suspension & Brakes Theory, alignment, spring rates....
spoon caliper clearance
Old Nov 3, 2009 | 10:34 AM
Drew17th's Avatar
Default spoon caliper clearance
so i am thinking about picking up a set of mugen NR's 15x6.5, +45, 4x100, 16.75 lbs. each. and wondering if they will clear my spoon calipers? or what size spacer i would need for this...
thx
and yes 4x100 with spoon calipers cuz i have a feeling someone will comment lol!
Old Nov 7, 2009 | 01:11 PM
Seedc2's Avatar
Default Re: spoon caliper clearance
I have been researching the combination recently and it usually comes down to spoke design and offset.
https://honda-tech.com/forums/showth...highlight=15x7
This is one of the archives I found that talks about fitment on 15" wheels.
"from user BlueR"
The following wheels FIT without the use of a spacer:
SSR Competition [15x7.5, +43 offset]
Buddy Club P1 QF [15x7, +42 offset]
Real Racing R2 [15x7, +45 offset]
USDM Stock ITR wheels [15x6, +50 offset]
Kosei K1 [15x7, +38 offset]
Advan RG [15x7.5, +42 offset]
Team Dynamic Pro Racing [15x7, +45 offset]
Volk TE-37 [15x7, +35 offset]
Volk CE-28N [15x7, +35 offset]
Racing Hart CP-035 [15x7.5, +40 offset]
Volk TE-37's [15x8, +43 offset]
SSR Type C [15x7, +38 offset]
ATS Comp-Lite [15x7, +35 offset]
Mugen MF10 [16x7, +43 offset]
Volk TE-37 [16x7, +42 offset]
Volk CE-28N [16x7, +42 offset]
Spoon SW388 [16x7, +45]
Enkei RPF1 [16x7, +35 offset]
Work Emotion CR [16x7, +42 offset]
The following wheels DO NOT fit without using a spacer:
Spoon Sw388 [15x6.5, +42 offset]
Volk TE-37 [15x6.5, +39 offset] requires a 8mm spacer
Kosei K1 [15x7, +45 offset] requires a 3mm spacer
Volk TE-37 [15x7, +43 offset] requires a 6mm spacer
UKDM Stock ITR [15x6, +50 offset]
JDM Stock ITR [16x7, +50 offset] requires a 5mm spacer
BuddyClub P1 QF [16X7, +45 offset] requires a 3mm spacer
Rota Slipstream [15x6.5, +40 offset] requires a 8mm spacer
Advan RG [16x7.5, +45 offset] requires a 5mm spacer
Advan RG [15x7, +44 offset] requires a 8mm spacer
Mugen MF10 [16x7, +50 offset]
Mugen MF10 [15x6.5, +45 offset] requires a 5mm spacer
SSR Type C [16x7, +42 offset]
5Zigen FN01RC [15x7, +42 offset] requires a 5mm spacer
No mention of your mugen NR's though.
Old Jan 22, 2013 | 07:33 PM
Tony M.'s Avatar
What about 15 inch RPF1s? Will those clear? With an offset of 35
Old Oct 11, 2020 | 12:51 PM
Civiclife@tec's Avatar
Bumping this as I desperately need to know if the spoon twinblocks will clear my 15 inch Enkie rpf1 +35, I don’t mind using spacers more worried about the caliper sitting inside the wheel okay and not catching the walls of the rim
Old Oct 12, 2020 | 05:29 AM
aw614's Avatar
10 Year Member
Loved
RPF1 in 15x7 +35 wouldn't clear my ITR calipers without spacers. I've heard of spacers being used, but I never went further to inquire as I was test fitting wheels that a friend had.
The 15x8 +28 will probably clear.
Old Oct 12, 2020 | 05:56 AM
I don’t mind spacers to much just worried the caliper will not actually fit inside a 15” rim without the top of the caliper catching the inside walls of the rim, I understand I may have to spacer to avoid the caliper catching the spokes
Old Oct 12, 2020 | 08:00 AM
aw614's Avatar
10 Year Member
Loved
Here was a thread on the ITR calipers which can be used as a basis for Spoons. But Im thinking a 15mm spacer might give it enough clearance if its further way away from the inner barrel .
https://honda-tech.com/forums/road-r...2836345/page2/
Old Oct 12, 2020 | 10:16 AM
So I’ve ordered the twinblock caliper I’ll put it on here with the outcome of how it goes when it arrives and have fitted it
Old Nov 18, 2020 | 10:29 AM
REC-ek's Avatar
The spoon calipers will fit inside the 15" RPF1 just fine, a spacer will be needed to clear the spokes. 3-5mm I'm thinking. I currently have spoon calipers and 15x7.5 Konig Hypergram wheels and a 5mm spacer is needed to make everything work together. I would recommend extended wheel studs as well. My stock wheel studs were too short after the spacer install for my comfort level. My 99 GSR is a track toy and only gets driven on the street to and from the track.
nostreble
Mar 15, 2016 05:17 PM
papa5murf
Honda S2000
104
Oct 4, 2015 09:09 AM
GiFF
May 18, 2010 05:39 PM
BlueR
Mar 29, 2007 10:11 AM
