Rubbing sound in passenger side wheel well
I have a weird rubbing sound in my front passenger wheel well. I am not sure what it is but it sounds like marbles rubbing together. The sound happens when I let my foot off the gas. When I start to brake the sound goes away or when I start to accelerate again. The sound also stops when I am driving and I turn the wheel towards the passenger side it also stops when I got above 70mph. I have no clue what it is. Please help. Also the car is a 1995 Honda Civic Dx the car is completely stock.
I get this problem every so often... It usually turns out to be something to do with either the brake calipers (or pads) or a wheel bearing. If the sound is more of a rattle, I would suspect the brakes; if its more of a scraping sound, probably bearings.
I never really had a "click" sound, though in that same situation I had a very definite "clunk" (the kind that makes your stomach uneasy)... Turned out to be a ball joint. After you have reversed the car and then put it back in drive, does this noise occur just as the car starts to pull forward?
Its not something that I've ever done myself, though I usually have to replace the front one at least once a year and the rear ones every couple of years. But I'm not very nice to my car... Its not an expensive repair to have done, but I don't remember exactly how much I've paid in the past... maybe $150???
96CivicEXSedan
Nov 24, 2013 06:19 PM
dc4teg95
Suspension & Brakes
Apr 5, 2010 06:41 AM
