Milling/CNC a v-band flange out of a T3 flange?
Old Nov 2, 2009 | 03:47 PM
97Alex's Avatar
Default Milling/CNC a v-band flange out of a T3 flange?
Any idea if its possible and feasible to mill out a v-band flange out of an old T3 cast exhaust housing? I'd like to convert a T3 to v-band, but don't want to bolt on a v-band using a welded on flange.
Old Nov 2, 2009 | 04:07 PM
k24em2's Avatar
Default Re: Milling/CNC a v-band flange out of a T3 flange?
Just weld a flange on to the housing
Old Nov 2, 2009 | 04:43 PM
DESTROYER's Avatar
What's wrong with using a welded on vband flange? Hundreds, if not thousands, of welded vband housings can't be wrong, right?
Old Nov 2, 2009 | 05:21 PM
Nick Z32's Avatar
yeah you can mill it or weld it.. just preheat the casting if you decide to weld it and your all set
Old Nov 2, 2009 | 06:30 PM
dave@passenger's Avatar
For the vast majority of available t3 hotside castings the answer is no. You can buy adapters or go the weld on route.
Old Nov 2, 2009 | 07:08 PM
97Alex's Avatar
Whops,
A little confusion here.
I'm talking about the exhaust housing INLET. I'm interested in converting both my stock exhaust manifold and stock turbine inlet to V-band flanges.
Does that change the answer to the question?
Old Nov 2, 2009 | 07:41 PM
DESTROYER's Avatar
I would just buy the TiAL piece.... just because it exists.
Old Nov 2, 2009 | 09:05 PM
Whops,
Machining alone will not work, welding would be in the ghetto, you need to buy the correct housing.
Old Nov 3, 2009 | 03:43 AM
-RedneckDave-'s Avatar
Working
I am going to have to agree with Dave and say that you should just get the correct housing (if it is available).
Old Nov 3, 2009 | 05:55 AM
Nick Z32's Avatar
yea go with Tial if you have an extra 1k$ laying around
Old Nov 3, 2009 | 07:42 AM
Manny@federal's Avatar
tial housings are less than 500 around here....
Old Nov 3, 2009 | 07:00 PM
Agtronic's Avatar
Tial housings are like $350 ...
http://www.atpturbo.com/mm5/merchant...Category_Code=
Old Nov 3, 2009 | 07:15 PM
9295EJ-t's Avatar
which are sick as Fukkk!
Old Nov 4, 2009 | 07:39 AM
same place i was looking lol, i just posted the high price...
Old Nov 5, 2009 | 03:14 PM
97Alex's Avatar
Actually, tial doesn't make v-band housings for OEM turbos nor an OEM exhaust manifold.
Grab a stock turbo and its exhaust manifold. Instead of mating them together with bolts I want to use V-band coupler. There aint no off the shelf parts for this stuff guys LOL.
I guess I was just asking if anybodies ever done it before and how many hours they logged into it for designing and machine work.
Old Nov 5, 2009 | 04:03 PM
Nick Z32's Avatar
wow.. sorry i really thought they wer allot more for some reason haha
Old Nov 5, 2009 | 04:29 PM
BMCRace's Avatar
We machined off the oddball 3.5" Vband on a s366, completely taper machined to a 4" vband and welded 4" normal (vibrant male/female style) vband on an exhaust housing in about 3 hours... The same concept could easily be done on the turbine inlet in probably the same amount of time.
Work like that is easy stuff to a machine shop that has fabricating capabilities. You should be able to get someone to do it for you for around $200 range. I wouldn't trust any yahoo that only has a 4.5" angle grinder, a few cut-off wheels and a die grinder as I would a machine shop though...
-James
Old Nov 29, 2011 | 01:13 PM
hootiehoo's Avatar
http://www.atpturbo.com/mm5/merchant...gory_Code=VVWM
bump it back to life!!
FlyNLow1987
Mar 8, 2014 05:40 AM
MooreBoost
Sep 14, 2004 07:55 PM
FyReo3
Jun 23, 2004 07:06 AM
phrasathane
Mar 29, 2004 07:13 PM
d98clturbo
Dec 27, 2003 09:39 PM
