To replace my O2 sensors first or Cat
Old Nov 2, 2009 | 02:24 PM
tlsole's Avatar
Default To replace my O2 sensors first or Cat
Sup Guys,
I have a 2000 Integra and my check engine light is on. Can you guys tell me which sensors i need? Also what do you guys think i should replace first? My cat or o2 sensors. My car has 180xxx miles and it exhaust fumes does smell like rotten eggs..
http://www.autopartswarehouse.com/se...Sensor%20Denso
Also, does anyone know any brand Cats that will fit directly to the OEM exhaust/header with OEM o2 bung. I searched but nothing came up..
Thanks guys!
Old Nov 2, 2009 | 02:39 PM
GagnarTheUnruly's Avatar
Default Re: To replace my O2 sensors first or Cat
Do you know how to get a readout of the CEL code? There's a way to do it easily in Hondas, and knowing the exact CEL code would pinpoint your problem.
Old Nov 2, 2009 | 02:43 PM
I should've posted this link in my post:
http://www.team-integra.net/sections...p?ArticleID=34
Tell us the code and we'll tell you what to do next!
Old Nov 2, 2009 | 02:54 PM
dntnedvtec's Avatar
yes!
Old Nov 2, 2009 | 03:43 PM
Originally Posted by dntnedvtec
yes!
Hey! Are you mocking my use of exclamation points?
I was just trying to be extra supportive of the person even newer than me. Plus now that I'm getting older I'm more secure in my expressive use of punctuation marks. Although I sill won't use smilies in emails to anyone other than my wife.
Old Nov 2, 2009 | 04:10 PM
mouab18c1's Avatar
Chill dude; im sure he didnt mean to mock you in anyway.
Old Nov 2, 2009 | 04:17 PM
dntnedvtec's Avatar
No, i didn't mean it that way. I mean it as that is the right answer for the op. I am sorry. I was also going to post the link as well.
Old Nov 2, 2009 | 05:44 PM
Oh, no I was totally kidding. My bad if it read wrong. I can see how that could happen now I reread my post. I'd edit with LOLs and stuff, but then people would just wonder what you were talking about!
So, yeah, sorry for that.
Old Nov 2, 2009 | 09:57 PM
Hektik Photography's Avatar
I'm not all great with this. but i have a 01 integra too. and currently in a tech school to study upon auto. i was reading up the technical service bulletins and remembered bulletins about rotten egg smells, and it would of been the bad cat. Um try bringing it to a near by jiffy lube station. If there is any nearby, they should be able to read your check engine light for you at zero to a small cost. Hope my info helps you
Old Nov 3, 2009 | 01:15 AM
ILS_09's Avatar
Please do not service your car at jiffy.Haven't you watch the news lately?Check on youtube on the awful service they provide to their customers.Learn to do everything yourself.Like I always tell others, who wants to pay 30 bucks for a ten minute oil change or 60 bucks for a/c recharge.Complete rip off.
Old Nov 3, 2009 | 02:09 AM
kulo's Avatar
will test pipe affect the o2 sensor
i keep getting cel light when im driving
its the main oxygen sensor
Old Nov 3, 2009 | 02:51 AM
Slain's Avatar
Has the OP figured out what codes your throwing ?
A test pipe will throw a code for the secondary o2 sensor and catalyst efficiency. The primary o2 sensor measures fuel trim.
Old Nov 3, 2009 | 03:24 AM
OH_1fstgsr's Avatar
This cat just cam off my 1999 GSR. Stock length.
This one might even work for you.
http://hondamarketplace.com/showthread.php?t=2669852
Old Nov 3, 2009 | 09:37 AM
PaulMc's Avatar
Painfully Stupid
Originally Posted by tlsole
Sup Guys,
Thanks guys!
You most likely need to replace the catalytic converter, you may not need to replace the sensor, the sensor isn't going to function correctly if the cat isn't functioning correctly, resulting in a CEL comming on. You haven't provided the codes so I'm just making an assumption; But for the high mileage on your vehicle, you may need to replace the oxygen sensor as well.
Get the codes and we can be of more help..
Old Nov 3, 2009 | 01:42 PM
tlsole's Avatar
Thanks for the info guys.. I havent figured out the code yet.. However, my brother-in-law has a OBDII reader that i will plug up into my car. Is that as accurate as the thing Gagnar is referring to? I will try both OBDII and the light flash thing. Ill keep you guys updated!
Old Nov 3, 2009 | 02:40 PM
The only advantage of the light flashing trick is that it's free. Code readers are $$$ and they give the same info as the flashing CEL trick (albeit with slightly less hassle). Either way, you'll get your answer.
Old Nov 5, 2009 | 12:02 AM
What i meant was that i only went to jiffy to get my code check, that's all. I do all the service for my car by myself. Rather have the feeling I did something to my car
PPWLUDE
Feb 23, 2010 04:40 PM
the-boulder
Oct 28, 2005 06:07 AM
impr323
Jun 21, 2005 05:29 PM
civicsicko
Jul 16, 2004 10:10 PM
py1188
May 17, 2004 06:37 AM
