Honda S2000 Honda S2000
help! How many quarts diff fluid for AP1? plz confirm..ive searched.
Old Nov 2, 2009 | 09:44 AM
esoterEK..'s Avatar
Default help! How many quarts diff fluid for AP1? plz confirm..ive searched.
can someone please confirm how many quarts of differential fluid is needed for the s2000?
ive searched and found 7/8 quart?
can someone please confirm.
also, ive bought one quart of royal purple 75w90 gear oil..
anyone have experience with royla purple??
any help would be appreciated..
thanks.
Old Nov 2, 2009 | 09:51 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Re: help! How many quarts diff fluid for AP1? plz confirm..ive searched.
search...
Old Nov 2, 2009 | 09:55 AM
S2KILLA's Avatar
and if u have already then u did a horrible job...
https://honda-tech.com/forums/showth...ighlight=fluid
Old Nov 2, 2009 | 10:19 AM
esoterEK..'s Avatar
none of those threads answered my question..all theyre talking about is what brand over another.
not how much is needed..
i guess im good with 1qt.
thanks for not reading..
Old Nov 2, 2009 | 10:50 AM
4doorH22's Avatar
.78qts IIRC, but that's neither here nor there. Just keep pumping until it comes out.
Old Nov 2, 2009 | 11:13 AM
S2KILLA's Avatar
actually dickbiter i answered your question several times over...
link #1 answered both questions...
"buy a helms....
raise car ( hyd. jack or lift)
jack stands
open drain plug
remove fill plug
let fluid drain INTO A PAN not the floor
reinstall drain plug tight......
with pump fill diff back up till fluid flows out...
pump can be found at any auto parts and makes it 150% way easier.
fluis is personal pref. i like royal purple "
link #2 discusses different fluids and what people use including royal purple which you asked in your original post...
link #3 also discusses different fluids just in case you wanted an alternative option...
So explain to me how I didnt answer your question??? I actually went above and beyond what you asked and you have to come back like a sarcastic *****... Maybe you should actually fawking search next time you lazy bitch...
Old Nov 2, 2009 | 12:38 PM
esoterEK..'s Avatar
LOL! still didn't answer my question...
thanks 4doorH22
plz /thread mods...
Old Nov 2, 2009 | 12:45 PM
bigmacnfries's Avatar
you guys gotta go metric one day...
Old Nov 3, 2009 | 06:08 AM
ReddotsS2K's Avatar
Fill it until it overflows out of the fill hole. Should be Around 1.2qt i think.
Old Nov 3, 2009 | 10:02 AM
QwikfamCTR's Avatar
How often do you guys change this?!
Old Nov 3, 2009 | 10:28 AM
SuzukaBlueAP2's Avatar
that's pretty much the way to do it. I don't think it takes a full quart though.
Old Nov 3, 2009 | 11:47 AM
90Rexx's Avatar
less than a quart of oil will fill the diff....
i reccomend amasol LE1605 along with many other people
Old Nov 3, 2009 | 12:11 PM
SirStig's Avatar
yeah it is definitely less than one. We did an ap1 and ap2 together at a tech day, both used less than one quart. This was the first time change and it was dirty as hell. I've heard every 60k to change
Old Nov 3, 2009 | 12:13 PM
CarsAddict's Avatar
as far as i know the oil doesn't make a difference...?
Old Nov 3, 2009 | 12:42 PM
ReddotsS2K's Avatar
Yeah your right, i always buy 2 though for some reason when i change it.
Whenever i have to replace the diff, which is like every 10k
Old Nov 3, 2009 | 12:46 PM
I would have to go back and look, but, I think the recommendation is far sooner than 60k miles. 25k rings a bell for some reason and sooner under more spirited driving conditions.
I first changed mine at 15k and I am due again at 22k.
Old Nov 4, 2009 | 05:13 AM
90Rexx's Avatar
honda reccomends S2000 diff fluid change every 15,000 miles
Old Nov 4, 2009 | 07:15 AM
ExVtec's Avatar
This.
Old Nov 4, 2009 | 02:42 PM
SirStig's Avatar
Hmm what the hell was I thinking of.. lol. must have talked about something else recently so 60 stuck in my mind.
Ladolcettad
Transmission & Drivetrain
12
Jan 12, 2012 07:18 AM
WaryDriver
Dec 26, 2011 08:14 AM
LittleGuy1972
Aug 21, 2011 02:54 PM
Bwright155
Sep 26, 2010 11:40 AM
AnthraxVX
Honda S2000
Jun 27, 2007 08:40 PM
