AMSOIL, just need a quick pointer :)
ok so i did search under S2000 threads, im looking to make sure i have the correct fluids before i order from amsoil.
Transmission Fluid from Amsoil:
Synthetic Manual Synchromesh
Transmission Fluid (MTF)
SAE 5W-30
Motor Oil From Amsoil:
100% Synthetic 10W-30 Motor Oil (ATM)
I dont really know what ATM stands for
Rear Diff Fluid:
i dont have a clue which one.
SEVERE GEARŽ Synthetic Extreme Pressure (EP) Lubricant 75W-90 (SVG) ?????
or
Synthetic Gear Lube SAE 80W-90 (AGL) ???
Thanks for the help ahead of time.
SAE 5W-30
Rear Diff Fluid:
or
At Amsoil.com, there is a place on the main page called, "Online Product Application Guide" then type in your year model and etc and there is a guide as to the best fluids to use for your vehicle. It will also tell you all the capacities of your vehicle as well as how many grease points you will have. Its pretty complete. You might want to print it out as a guide for future use.
06BlackSi #45
Honda Civic (2006 - 2015)
Sep 29, 2008 01:33 PM
