How much Boost can a stock H22 handle??
I want togo turbo... but idk if for now I could just put on a kit that I have sit'n in my room... could I run 5psi. with out doing damage to the motor daliy driving...?? (Y/N)
It depends on how big of the turbo size you have. You can run high boost on a small turbo and it would be the same as low boost on a big turbo.
Give information on what turbo size you have then we all can tell you how much PSI you can push out of the turbo.
Yeah he is right you can't there are more factors then you know Sir volumetric effiency, CFM the motor can flow, fuel system, other supporting mods, what type of ecu your running and so many others. Yes you can find the turbo size. There are to many factors but hey if ya wanna do a daily driver get like a 57trim turbo or a 60 trim and run like 10 psi and you will still have room to grow a little and you will be happy.
