b18c type r swap in 90 integra-ecu throwing out CEL code 26 WTF!!?? HELP!!
Old Nov 1, 2009 | 01:18 PM
mrafd's Avatar
New User
Default b18c type r swap in 90 integra-ecu throwing out CEL code 26 WTF!!?? HELP!!
Hi there
this is out of desperation basically, i go to start car and it cranks at a normal speed but doesnt want to fire up. it was sounding like it a bit for a minute. sounded like something came out the exaust pipe for a quick second. checked for spark and its good,checked for fuel and there is fuel at the filter and at the injectors aswell, i checked the spark plugs and they smell like gas a bit but they are not drenched or anything.also looks like the top of the pistons are a little bit wet with gas so im sure the injectors are firing, not to sure if its to lean or not??
only CEL code coming up is this 26...i turn the key to ON and the engine light comes on when the ecu powers up and then it goes out and it goes...6 quick flashes and then 2 long ones, then it goes 6 quick and 2 long and so on and so on and it keeps going, i unplugged the vtec oil pressure switch to see if it would throw a CEL correctly for that and it did, it threw a 22, two long flashes and then 2 quick flashes, so i know its working. i have a obd1 conversion harness with a chipped obd1 ecu running from a obd harness. im very confused as to whats going on here, this engine is a jdm b18c 96-97 with h/i/e, no a/c or p/s.i soldered all my wires up and im using no resistor box with the injectors that came with the engine,im using the obd2 dizzy rewired from obd-obd1-2.the fuel pump works fine and the battery is good. im stumped here can someone try and help me out on this..i just want to get the thing running here!!
thanks!!
Old Nov 1, 2009 | 01:24 PM
mrafd's Avatar
New User
Default Re: b18c type r swap in 90 integra-ecu throwing out CEL code 26 WTF!!?? HELP!!
p.s you can check the obd1 cel codes to, there is NO trouble code 26 in the list, i looked at about 20 lists here on the net and no 26 at all. for some reason i am suspecting a fuel issue because there should be more gas on the plugs and in the chamber ect, but fuel injector cel code is 16 and its not throwing a 16 , its definitly a 26. i tryed it like 10 times to make sure..
Old Nov 1, 2009 | 01:27 PM
mrafd's Avatar
New User
Code 0 and 11 Electronic Control Module (ECM)
Code1 Heated oxygen sensor A
Code 2 Oxygen content B
Code 3 and 5 Manifold Absolute Pressure
Code 4 Crank position sensor
Code 6 Engine coolant temperature
Code 7 Throttle position sensor
Code 8 Top dead center sensor
Code 9 No.1 cylinder position sensor
Code 10 Intake air temperature sensor
Code 12 Exhaust recirculation system
Code 13 Barometric pressure sensor
Code 14 Idle air control valve or bad ECM
Code 15 Ignition output signal
Code 16 Fuel Injector
Code 17 Vehicle speed sensor
Code 19 A/T lock-up control solenoid
Code 20 Electric load detector
Code 21 V-TEC control solenoid
Code 22 V-TEC pressure solenoid
Code 23 Knock sensor
Code 30 A/T FI signal A
Code 30 A/T FI signal B
Code 41 Heated oxygen sensor heater
Code 43 Fuel supply system
Code 45 Fuel supply metering
Code 48 Heated oxygen sensor
Code 61 Front heated oxygen sensor
Code 63 Rear heated oxygen sensor
Code 65 Rear heated oxygen sensor heater
Code 67 Catalytic converter system
Code 70 Automatic transaxle
Code 71 Misfire detected cylinder 1
Code 72 Misfire detected cylinder 2
Code 73 Misfire detected cylinder 3
Code 74 Misfire detected cylinder 4
Code 75 Misfire detected cylinder 5
Code 76 Misfire detected cylinder 6
Code 80 Exhaust recirculation system
Code 86 Coolant temperature
Code 92 Evaporative emission control system
Old Nov 1, 2009 | 04:02 PM
Stinkycheezmonky's Avatar
Suspetise...
Moved to Hybrid where it will probably get a better response.
6KAOS6
Jun 4, 2011 05:55 AM
CDizzle_996
Mar 10, 2009 05:01 PM
G_S_R
May 3, 2004 03:17 PM
EuN_TeK
Mar 15, 2004 10:32 AM
