Random low idle on cold days
Okay so like the title says sometimes on cold days after i drive for a little my idle will be very low lately it has actually started to die. Normally my idle is fine and sits solid at 750, it never does it on warm days and it doesn't always do it on cold days. Usually it goes away when the engine warms up but not always. I would think this is iacv related but i recently cleaned it. Does anyone have any ideas what could be causing this.
well i didn't think adjusting the idle screw would help because normally it idles fine it seems like if i adjust the idle up it will be too high most the time. I doubt it is the pcv valve mine is not more than three months old. It is possible a hose could be clogged i guess... i will check that
For my OBDII Civics, I find that adjusting the idle screw to the highest point that still maintains the idle speed at spec yields the most steady idle under all conditions. At least for OBDII Civics, you seem to be able to turn the idle screw quite a bit before the idle speed changes, most likely due to the ECU's capacity to compensate under widely varying conditions.
By the way, the idle adjustment procedure varies with engine type. You have an OBDII B16a2 engine and an OBDI ECU and throttle body (right?), so I am not sure whether you use the B16a2 procedure or the OBDI Civic procedure to adjust idle speed.
Also, have you already adjusted the ignition timing to spec using a timing gun?
Yes, the screw on the throttle body. Does the IACV have an adjustment screw?
I would think i use the obdi procedure... but what is the exact procedure so I can make sure I am doing it right.
well i checked today the idle is set exactly right when it is warm it idles at 450 with the iacv unplugged and then it goes up to 750 when the iacv is plugged in. I think i will try cleaning the iacv and fitv again and see if that does anything.
