Block number
Can anyone post a picture or tell me where to find the block number on the engine.. I have a 95 Accord EX and it doesn't have the original engine in it.. Any help would be great...
It is located above the center engine mount. If you look down between the exhaust manifold and upper rad hose you will see the engine ID code.
The US 95 Accord EX originally cam with an F22B1 VTEC (Canadian 95 EX came with the F22B2 Non VTEC)
OK.. I checked it out.. Found the HA but below where the F number is supposed to be it is completely blank! There is however a long barcode sticker to the left but has doesn't have any F or H type number.. Any idea's??
Try pouring a little bit of water on it. I saw that when I was cleaning up the engine one day I could read the code more easily. It's there, but you can't read it because it's reall dirty. And that barcode sticker is probably the tranny code ( 5 speed)
oh yah and you can also check the on the timing belt cover if the barcode sticker is still there. it should have a code, then followed by "f22xx" F23xx" H22xx, H23xx or whatever
mrbleh
Jan 15, 2014 03:03 PM
civiclov5u
16
Feb 23, 2011 08:10 PM
blueaccord90
Feb 25, 2005 06:42 PM
