How to get engine rpm higher
Old Oct 31, 2009 | 06:46 AM
Rob97'SH's Avatar
Default How to get engine rpm higher
While the engine is still waiting to get sleeved and all the parts are being clean. I'm looking into how to get the red line higher. I know stock valve train won't cut it but does anything else need to be looked at?
H22a4
comp 10-1
cp pistons
eagle rods
supertech valve train
race bearings
Balanced crank
goldeneagle sleeving
These are what will be going in it.
Old Oct 31, 2009 | 08:13 AM
nus_dogg's Avatar
Default Re: How to get engine rpm higher
I'm not sure either since you're going to be built. I think you should be ok since you won't be having OEM internals.
What cams are you going for? or just staying OEM?
Old Oct 31, 2009 | 08:15 AM
NirVTEC's Avatar
H22a4
comp 10-1
cp pistons
eagle rods
race bearings
Balanced crank
So you built it for boost? Assuming that since you did a 10:1 build and your SIG says 335whp.
Installing the S2 VT with Stage1[n/a] cams raised my powerband about 500rpm.
I would look into WEB Cams, and wouldn't bother with the Crowers[even though people have said they make good power[which ive yet to see N/A], the company sucks] Skunk2 also makes a Stage1 and Stage2 Turbo cam.
Bisi should be able to lead you down the right path.
From what I have seen, stock cams with a nice valvetrain and Boost, make for a nice ~8000rpm setup. A lot of the 400-500-600whp H guys are using stock cams.
eggsxr
Dec 28, 2014 07:07 PM
m4xwellmurd3r
Apr 5, 2013 10:20 PM
EncoreRSX
Feb 16, 2009 01:33 PM
b.d.racing
Jan 1, 2006 12:46 PM
ChaosUnbound
Jan 14, 2004 05:33 PM
