My new Momo steering wheel is off center, how to fix?
Old Oct 29, 2009 | 09:07 PM
Rob.'s Avatar
Icon2 My new Momo steering wheel is off center, how to fix?
I installed a new momo steering wheel, which uses a standard MOMO hub. It is a lil off center now. One spline to the left and it is off center in the other direction. I did install the hub correctly with the spot marked top at the top.
After a search, it looks like the only option is to adjust at the tie rods. Does anyone know how many degrees one turn of the tie rods will accomplish at the steering wheel. I really only want to have to do this once .
Sample pic of what I mean.
Old Oct 29, 2009 | 11:28 PM
91DBSexyTime's Avatar
Default Re: My new Momo steering wheel is off center, how to fix?
Probably alignment, my civic is the same way, you get used to it.I bet your front tires look like they doing the splits a little? huh..
Old Oct 30, 2009 | 01:36 AM
quirarte626's Avatar
well it all depends on the hub i guess..
just set it off a little to the left and tighten it up like that and then ur wheel will be straighten..
my steering wheel sits upside down =P
Old Oct 30, 2009 | 05:27 AM
hatchet_honda's Avatar
yea..mine looks the same way. never could get it straight
Old Oct 30, 2009 | 11:34 AM
solorex's Avatar
Go get an alignment done. A proper alignment machine has a brace that locks the steering wheel to the floor of the car, centring the steering wheel.
Old Oct 30, 2009 | 01:52 PM
Rob.'s Avatar
I got an alignment done. Problem fixed.
swizz977
24
Jan 20, 2014 12:05 PM
Spaceballsthelunchbox
May 30, 2013 05:45 PM
ScottF
Mar 29, 2010 11:02 AM
vti444
Jun 16, 2007 02:36 PM
citanest
Apr 21, 2002 01:15 PM
