Ignition lock cylinder stuck ON?
Old Oct 29, 2009 | 05:41 PM
Syper's Avatar
Default Ignition lock cylinder stuck ON?
So I went and removed the ignition lock cylinder. I decided to put the key in and turn it to see if it still worked (it did) but then it was stuck in that position? The key came out normally, but the lock is stuck in the on position. I tried wd40 and tried turning it with pliers and such and still nothing.
Here are some pics:
Old Oct 30, 2009 | 05:37 AM
hatchet_honda's Avatar
Default Re: Ignition lock cylinder stuck open?
lock stuck open?? like..stuck in the on position now?
Old Oct 30, 2009 | 09:05 AM
Syper's Avatar
Yes
Old Oct 30, 2009 | 12:31 PM
racingcrx's Avatar
Default Re: Ignition lock cylinder stuck ON?
i had that happen to me. i couldn't get it back to the off position. might need to get a new one
Old Oct 30, 2009 | 12:48 PM
Syper's Avatar
ahhhh!!! I barely got it too. lol I was soo happy that I was gonna have 1 key for the whole car!!!
Anyone had this happen as well and got it unstuck or fixed it??
Old Oct 30, 2009 | 08:42 PM
Syper's Avatar
bump...
Old Oct 31, 2009 | 10:06 AM
did you try pushing in on the key as you turn? if its that diff to turn the key in the cylinder back to the off position then id say its faulty
Old Oct 31, 2009 | 01:38 PM
Syper's Avatar
Yeah, I did that already. I've pushed in and tried turning it with pliers and no luck. The thing that sucks is that It was working 100% before I took it out and turned the key!!
Ugh!!!!
Old Nov 1, 2009 | 07:41 AM
91highryda's Avatar
Ugh!!!!
yeha im in the same problem bro u have to get a whole new ignition man with new keys!!! mine worked fin with a key and it got sruck on and everythime i hit the clutch starters working and grinds( soo look on ebay for a ignition lock clinder key for ur ef or go to any part store and get one there really cheap for ef unlike my integra at 100 plus for all the wires n **** so good luck man hope i helps u out some more
Kelly Obrien
Jul 9, 2019 02:36 PM
2001GSRSC
Oct 3, 2017 07:49 AM
Steve LeB
Aug 30, 2012 01:08 AM
ekkscott
Honda Civic (2001 - 2005)
Jun 6, 2012 02:45 PM
donut.
17
Jan 11, 2010 07:03 AM
