Suspension & Brakes Theory, alignment, spring rates....
differance between eg and ek front forks
Old Oct 29, 2009 | 03:14 PM
goldgreen90ef's Avatar
Default differance between eg and ek front forks
hey guy, i just took off my jic magic suspension that came on my ek( too stiff for my old ***) im starting to think that they used front forks off of a eg to make the jic's work, cause i got a setof suspension off of a em1 (00 si) struts with h&r springs, and the struts dont fit into the front forks. and before you say "search button" i have searched and am 99% sure, just need conformation. so my actutal question is, eg front suspension forks hole is to small to accept ek struts? thanks and my bank account thanks you!
Old Oct 29, 2009 | 04:04 PM
vietjdmboi's Avatar
Default Re: differance between eg and ek front forks
im using apexi n1 susp from an ek on my eg. everything up front fits fine. its just the rear bottom fork thats different.
Old Oct 29, 2009 | 04:38 PM
did you use ek front forks?
Old Oct 29, 2009 | 05:00 PM
vietjdmboi's Avatar
i used my eg forks.
Old Oct 29, 2009 | 05:31 PM
i used my eg forks.
thats weird than what fork could have been used w/ jic's that wont work with em1, integra or somethin ?
Old Oct 29, 2009 | 06:56 PM
i think i found the problem... i have ef/da front forks which have a smaller hole. can anyone confirm that ef/da have smallr holes than eg/ek?
Old Oct 29, 2009 | 07:13 PM
PIC Performance's Avatar
Yes, 88-91 Civic front forks have smaller openings for the shock than the later generations
Old Oct 29, 2009 | 07:19 PM
^^^^^^^^^^^^ YOU RULE!!!^^^^^^^^^^^^
thank you, you just solved my problem, my jic's weere from a ef/da installed on myek w/ washers in the rear and da/ef front forks.
Old Oct 29, 2009 | 08:08 PM
kommon_sense's Avatar
I'm not quite sure where the ef/da front forks fit into this. However the 99-00si has wider forks than other civic models. I believe that 94-01 integra an 92-00 civics use the same front fork (with the exception of the 99-00si).
Old Oct 30, 2009 | 05:02 AM
the ef/da forks come into play because i had ef/da coilovers on my ek, sold them and was left with the forks thinking they would fit into ek struts. well they dont and i need 92-00 civic or 94-00 integra. EXCEPT EM1 , cause the fork is wider at the bottem of the 00 si like you said, thanks
Old Oct 30, 2009 | 08:01 PM
I've got a set of 98 integra forks. PM me if interested.
evo951
Apr 12, 2010 10:53 PM
724chris
Feb 5, 2010 05:09 PM
goldgreen90ef
Oct 29, 2009 07:20 PM
1 jonesie
May 20, 2007 05:08 PM
