oil change and additives
Old Aug 30, 2002 | 11:37 AM
turrismaldon's Avatar
Default oil change and additives
this is my first time here in norther michigan so i would like my honda accord '90 Lx be ready for the winter season... i just got it 3000 miles ago( its now at 146,000 mi) so its time for oil change! would you reccomend i use additives? should i use synthetic oil? whats the oil to use so that i might see my honda reach the 200K mark or even teh 300K mark as some of my friends say!
and lately i have been hearing lick a clock ticking just when i parked the car?
thanks for any assistance and suggestions
Old Aug 30, 2002 | 11:39 AM
Gennady's Avatar
New User
Default Re: oil change and additives (turrismaldon)
Use regular oil from Castrol or Mobil, not synthetic. You can use some fuel injector cleaner once in a while, it wont hurt.
Old Aug 30, 2002 | 11:49 AM
Default Re: oil change and additives (Wont be beat)
what kind of oikl? 5x30 or a 10w30 or should i use the high mileage oils? thanks Have a great day
Old Aug 30, 2002 | 11:59 AM
Gennady's Avatar
New User
Depends on your climate. High milage oils are fine too.
Old Aug 30, 2002 | 12:29 PM
Brandon's Avatar
Life is Suffering
All Hondas require 5w-30 because of the tight tolerances on the engine.
Old Aug 30, 2002 | 03:18 PM
wizurd's Avatar
Default Re: oil change and additives (F22turbo)
I use 10w/40...but only 'cause it gets so hot here in the summer.
Think I should change?
Old Aug 30, 2002 | 03:36 PM
Razor's Avatar
Default Re: oil change and additives (wizurd)
5W-30 is perfect for 4 cyl accords all year around. i would put 4 quarts of 5w-30 and than a can of BG MOA. bg moa reduces engine sludge and keeps the oil in good condition. for total maintanance, i would add a can of 44k every oil change(to your gas tank). make sure its full though.
Old Aug 30, 2002 | 04:33 PM
Brandon's Avatar
Life is Suffering
Default Re: oil change and additives (Razor)
I also put Restore in every two oil changes, it actually makes a difference.
Old Aug 30, 2002 | 04:39 PM
wizurd's Avatar
It's called "restore"?
Old Aug 30, 2002 | 04:44 PM
Brandon's Avatar
Life is Suffering
Yeah, it comes in a sliver can that looks like Red Bull (my friend almost made that mistake).
Old Aug 30, 2002 | 05:06 PM
wizurd's Avatar
Is this this same or about the same thing that Razor is talking about?
Old Aug 30, 2002 | 05:09 PM
Brandon's Avatar
Life is Suffering
No. Restore promotes a better ring seal.
Old Aug 30, 2002 | 05:31 PM
wizurd's Avatar
I have a 144,000 miles....think it's going to make a difference?
Old Aug 31, 2002 | 06:11 AM
Gennady's Avatar
New User
Is it like a sludgy type of goo?
Old Aug 31, 2002 | 06:31 AM
Gen4-5Door's Avatar
I also agree with razor. BG MOA is a great additive. Motor oil is made up of two parts, your petrolium base and your additive package. MOA is an 8 oz can of the additive package and it works really well. What ever you do, do not use Slick 50!! I used it i an old 4 cyl truck that I had and it started to burn oil!! As for the mileage that you get on your 90 LX, I hope that you can reach at least 300,000 mi. My 91 EX wagon is at 189,000 and still going strong. Just remember to do the timing belt every 90,000 with an original Honda belt and replace the water pump at the same time. This is very important!! Enjoy your new accord.
Old Aug 31, 2002 | 09:34 AM
Razor's Avatar
Default Re: oil change and additives (Gen4-5Door)
yeah theo only BG products i recommend are the BG MOA(oil additive) and BG 44k(fuel additive, cleans carbon buildup in intake manifold and fuel injectors, make sure you add when you have a full tank of gas).
Old Aug 31, 2002 | 09:37 AM
Kazmans94cord's Avatar
can you pick up these BG products at any autoparts store? ive never seen them at o'reilly's
labeldc5
15
Feb 26, 2008 01:08 AM
v0lcom27
22
Jul 13, 2005 07:30 AM
BoBo Racing
Honda S2000
Aug 24, 2003 07:03 PM
Evil_Wizard
52
Oct 28, 2002 09:05 AM
CTR94Joes
Jan 27, 2002 11:03 AM
