17x9 +35 all around?
Looking for a street class NA AP1 Time Attack/Time Trials/HPDE set up. Evasive Motorsports suggested I run a 17x9 +35 wheel in all four corners. Will this work? I've seen it done on S2KI, but I'm not a member there. Was looking into RPF1's.
It will work yes, but not too easily. You will definitely need some camber work and fender rolling + modification of the rear bumper slightly. Alot of it also depends on how low you are.
From: "That one guy with that one car" Kennewick WA
yes do this^^ i put my rear wheels up front to see if they clear my spoon calipers (17x9 +45) and they worked out pretty well considering the 15mm spacers
. but... but i am running -2.25 camber and rolled, slightly pulled fenders.
rears should be easy with a quick roll and bumper tab relocation.
GL
. but... but i am running -2.25 camber and rolled, slightly pulled fenders.rears should be easy with a quick roll and bumper tab relocation.
GL
Because this sounds like a hard-parkng wheel, not an offset for serious track work.
