CHECK ENGINE LIGHT need help!
Old Oct 29, 2009 | 01:00 AM
91teg_ls's Avatar
Default CHECK ENGINE LIGHT need help!
i have a 95 civic ex coupe with a mini me swap that is a d15b7 bottom end, and d16z6 top end. i am getting a cel. the code i am receiving is 22 (vtec pressure switch). i have swapped the vtec solenoid out 3 different times. and the only thing that i can think of is it is not getting enough oil to the head. but iirc the b7 and z6 have the same oil pumps. can someone help me trouble shoot this problem.
Old Oct 29, 2009 | 06:56 PM
91teg_ls's Avatar
Default Re: CHECK ENGINE LIGHT need help!
need help!
Old Oct 29, 2009 | 11:23 PM
91teg_ls's Avatar
help!
Old Oct 30, 2009 | 01:28 AM
91teg_ls's Avatar
ttt
Old Oct 30, 2009 | 09:08 AM
91teg_ls's Avatar
help me
Old Oct 30, 2009 | 09:31 AM
accord2civic2prelude's Avatar
which ecu are you using? try jumping pin A4 and D6.
Old Oct 30, 2009 | 12:53 PM
91teg_ls's Avatar
i have a p28 mt ecu
Old Oct 30, 2009 | 02:01 PM
Relic1's Avatar
did you did follow the many write ups on how to get oil into the head for the VTEC solenoid?
Old Oct 30, 2009 | 02:04 PM
havok hybrid's Avatar
There is a oil restrictor in the middle of the cylinders on D motors. You have to remove this when doing a mini me. vtec swap. That is most likely the problem .
if not you can get the ecu chiped to not look for the oil pressure sensor.. ?
Old Oct 30, 2009 | 02:40 PM
91teg_ls's Avatar
yes i have read the many write ups for the mini me swap and i pulled the oil restricter out. the car has ran a year with no problems and this happens.
Old Oct 30, 2009 | 05:14 PM
91teg_ls's Avatar
still need help!
Old Oct 30, 2009 | 09:05 PM
91teg_ls's Avatar
still waiting on some help/
Old Oct 31, 2009 | 12:14 AM
91teg_ls's Avatar
could it be possible that i have a bad oil pressure switch
Old Nov 2, 2009 | 08:51 AM
did you double check your wiring. maybe a wire is messed up at the ecu.
look up how to bypass vtec oil pressure. that might give you a option
Old Nov 4, 2009 | 01:42 AM
91teg_ls's Avatar
cool, and i am using a the z6 harness. do you think that it still may be messed up?
Old Nov 16, 2009 | 08:46 PM
91teg_ls's Avatar
what would this do?
Old Nov 16, 2009 | 09:21 PM
91teg_ls's Avatar
i need some help/
Old Nov 17, 2009 | 12:28 AM
TaTuned's Avatar
you better make sure that all your wiring is soldered together so you dont have any loose or bad connection cause that happens alot make sure your connections are soldered together then heat shrink it might work
Old Nov 17, 2009 | 10:58 AM
91teg_ls's Avatar
this is a uncut harness.
Old Nov 17, 2009 | 09:43 PM
91teg_ls's Avatar
vtec is fixed. i bought a new oil pressure switch fir the vtec solenoid and now vtec is working and my cel is gone. but i still have the idle surge.
jasonboyce03
Feb 27, 2012 04:49 PM
lojackgsr
Jun 24, 2007 11:17 PM
crowder13
Mar 11, 2007 09:53 PM
allmotorcrx2001
Jul 5, 2006 08:20 AM
Rywire
Jan 11, 2003 08:49 PM
