Help Honda Civic Crankshaft bolt STUCK???
Old Oct 26, 2009 | 09:36 PM
EG-SIXV-TEC's Avatar
Icon6 Help Honda Civic Crankshaft bolt STUCK???
Please honda Tech i need Help i don't know what to do?
I just got my used hatchback and the current guy did a timing belt change...
The frickin main timing is off retard? by couple of teeth .
obviously the previous mechanic is dumb ***.
im tryin to take off to correct the main timing.....
The main concern is that, im trying to take the crank bolt off to take the belt off. and its Stuck, super stuck like its welded.
i tried to take the bolt off with even a Snap ON Impact gun new 800ft lbs- which i borrowed from my friend.
idk if he put LOCK TITE or some S*** like that its hard to come out..
Please help is there a tool to jam the crank dampaner for honda?
my next plan is to jam the flywheel starter side, lock the crank side,
-Then use a large braker bar, to crack the bolt.
Which way to remove the crankshaft BOLT off, just we were going left side i think to the headlight????
Remedies, i don't know what else to do is it worth it or will the crank bolt brake?
HELP
Old Oct 26, 2009 | 09:54 PM
civic_r87111's Avatar
Default Re: Help Honda Civic Crankshaft bolt STUCK???
If u just want to correct the timing then u don't need to take the Crank pulley off, just loosen the tension pulley bolt and slide the belt off the cam gear. U can buy the tool to hold the crank pulley on ebay for pretty cheap. BTW if it's off a couple of teeth then I would say u have some bent valves as well.
Old Oct 26, 2009 | 10:07 PM
ill try do that, but what about the crankshaft bolt i still
have hard time still takin it out?
To remove the bolt is it left or Right and which side im just checking, because the bolt is dam hard to come off???
Old Oct 26, 2009 | 10:36 PM
eg grom's Avatar
Have you tried tapping the bolt with a hammer or using an anti-seize lubricant?
Old Oct 26, 2009 | 10:38 PM
U mean is it left or right hand thread? The tensioner bolt is under a rubber plug on the timing belt cover and u just need to loosen it, not remove it.
TravisCadello's Avatar
a big 1 inch impact wrench was the only thing that got mine off.
thumper64's Avatar
You can make or buy a crank pulley tool. That and a big huge lever to gain leverage should get it loose. I have a friend with a Snap On impact and it failed, big time just taking out trailing arm bolts.
Old Oct 26, 2009 | 10:43 PM
IR impacts!!.. As for the 1" impact hellz yeah it will get it off, a 3/4" should also, lol
Old Oct 27, 2009 | 12:41 AM
38genesis's Avatar
torch it, then spray wd40 when its still hot, then try turning it with a wrench. dont use impact gun you might break the head
Old Oct 27, 2009 | 03:35 AM
hondamark35's Avatar
a great big gun won't do any good unless you have a good compressor and air hose to feed it.
like was already said, get the special crank holding tool and a long breaker bar (i like using chain-link fence rail pipe and a 1/2in Craftsman wrachet. good fit and 6' of leverage!!) don't forget your lube!!!
Old Oct 27, 2009 | 05:19 AM
R666_EK's Avatar
Torching the crank is not really recommend by many.
I have always had good luck with impacts and plenty of WD-40 or PB Blaster.
But if those don't work, the crank pulley holder tool, and a BAF Breaker bar should do the trick.
Old Oct 27, 2009 | 07:18 AM
boosting sol's Avatar
x2
Old Oct 27, 2009 | 07:41 AM
kaiba's Avatar
I use the Harbor Freight Earth quark impact gun 1/2". Works everytime for me.
Use the impact to tighten it and reverse it. May need to repeat process couple times.
Jose Guerrero
Oct 16, 2016 08:31 PM
SpOoLiNg CiViC
Jan 3, 2007 05:07 PM
freezerburnv2
May 14, 2005 06:50 PM
hludersh98
Oct 17, 2004 08:35 PM
